(shop) air regulator/filter suggestions
   / (shop) air regulator/filter suggestions #1
disney
orlando fl
scag turf tiger 61" #2, gx95, sold f525 twice, f725 sold
Good morning all! I am nearing the completion of a 120gal compressor install, (converted to 5hp), and discovered my planned-to-be-used new snap-on 1/2" filter/regulator set max is 150 psi, and my compressor is 175:( I know I could adjust the pressure switch to cut off sooner, but I would rather not do that (long story, just go with me...) I actually have a different filter that is rated to 250 psi, with 1/2" npt, but would still need a good regulator. I don't care if a by a new combo, or just a regulator, but I would like to buy (reasonable) quality, at good price. I do not want to go any smaller than 1/2", and would not like to go larger than 3/4, but willing to if need be for a better unit, or great deal. As always thanks in advance to all to help.
   / (shop) air regulator/filter suggestions #2
just picked up a couple from northern tools for a couple customers they are 200psi ingersoll rand brand very good quality should be about $60.00 both are adjustable and quite heavy metal construction good luck
   / (shop) air regulator/filter suggestions #3
Is there some reason you want to run at 175psi??? Thats way high for air tools. 90psi is rated pressure. I run at 120psi usually, but 175 is considerably higher than that. Wont do much for longevity./
The current SO filter regulator PN AHR430 is rated for 250psi in . If you have to have 175psi for some specific reason, just bypass the filter/reg combo and run straight from the tank to that tool. Put your other filter on that high pressure unregulated line
   / (shop) air regulator/filter suggestions #4
they were putting them in line for shop use they run alot of 1 inch air guns also it is the government what they take off they must return with same most what they do is overkill but it works
2007 Case IH 2588 4WD Combine (A50657)
2007 Case IH 2588...
2019 Club Car Carryall 1700 4x4 Diesel Utility Cart (A48082)
2019 Club Car...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A52128)
NEW 2025 Load...
2017 Ford F-550 Bucket Truck - 4x4, Powerstroke Diesel, Versalift VST47, 52FT Reach (A52128)
2017 Ford F-550...
2010 POLARIS RANGER 4X4 4 SEATER UTV (A51222)
2010 POLARIS...
2005 Big Tex 10PI 16ft. T/A Utility Trailer (A49461)
2005 Big Tex 10PI...
