shooting back stop
   / shooting back stop #1
old243
dundalk ontario
komatsu pc15
I have been following the tread, on shooting benches. What do members use for a back stop. In my case I have 5 highway trailer tires, they are still mounted on rims sitting on a pallet. Also they were free . Mine is wood, wish I had a metal one as it will rot out eventually. I drove a couple of T fence stakes inside to hold them stable. Set my target in front of the tires. I have been using it for five or six years now.
A 22lr bullet will barely stick into the tire. A243 will go through the tire and remain inside it. A 308 using nosler partition bullets will go through the first rim. and stops at the second rim surface . A 12 guage slug will do the same. None of the bullets dinge the second rim surface. If you mutilate the one side you could turn it a bit, to get a different surface. I do a lot of shooting and mine is still good. I could have filled the center with sand, but wanted to be able to move it if necessary . With the fork lift. My land is fairly flat so have no berm or hill to shoot into. This has worked well. old243
   / shooting back stop #2
I just dug into the side of the mountain a bit with the backhoe (most of the way up and on a nice large flat spot) and used that. Makes a backstop that is about 50 yards high and maybe a ¼ mile deep. The great thing about our state is it is really easy to find a good backstop for shooting - now flat land is a whole different thing......
   / shooting back stop #3
I have a railroad ties stacked at the base of a steep hill. I'd have to shoot about 45 degrees up to shoot over the hill.
2011 Toyota Corolla Sedan (A53117)
2011 Toyota...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2015 CATERPILLAR CT660 TANDEM AXLE DUMP TRUCK (A54313)
2015 CATERPILLAR...
2016 Ford Explorer AWD SUV (A55758)
377789 (A51573)
377789 (A51573)
