shoe or not to shoe?
   / shoe or not to shoe? #1
yooperterry
SAult Ste Marie Mi
John Deere 2025R
Was going to upgrade my snowblower on my 2025 john deere to a front mounted blower. However after being told by my dealer that it was "no big deal" to change between the blower and bucket, I seen that it was quite more than I would want to do in the winter here in the U P of Mich. So after selling my old agrotrend blower, than finding out about the amount of work changing over/back to blower and or bucket I purchased a new J D 54 rear blower. Unlike the old agro, JD has shoes on it. Driveway is gravel, seems the shoes cause more trouble than the agrotrend without shoes! They dig into driveway, sod on edge of driveway. Thinking I might just remove the shoes and use it that way. Agrotrend did not seem to be so damaging?? Any Ideas on this? Yooperterry
   / shoe or not to shoe? #2
Run shoes on my Lucknow but I fabbed and welded my own brackets on and I use the mushroom shaped shoes from a Meyers plow blade.
   / shoe or not to shoe? #3
You may need to run an inch or two high until the ground hardens up or you get a layer of hard pack snow.
   / shoe or not to shoe? #4
Adjust your top link so the the edge of the blower is either tilted up a bit or flat vs tilting down (which would tend to make it dig in easier)
   / shoe or not to shoe? #6
yes until the base is very well frozen it will be pretty difficult to blow snow without picking dirt and gravel. I usually use a rear blade turned backwards so it doesn’t dig in until the base gets well frozen.
   / shoe or not to shoe? #7
Shoes vs not always a big debate, especially if you don’t have fancy custom fabricated ones. Sorry I’m not much help. I’m also in the UP.
   / shoe or not to shoe? #8
I DIY'd a pair for my blower.
I welded 10" strips of 2.5 X 12" with both ends shaped like ski tips to the bottoms of the flimsy factory skids.
That was some 5 years ago and since then I've reduced my sheer bolt usage to but 1 or 2/ year* while B4 I'd need dozens.
I simply lower my blower and let it float as I blow my way along.
Luck was with me as I had some T1 (hardened cutting edge material) to make my oversized skids from.
*and that is usually from something the city plowed into my entrance.
It is simple easy DIY project for those that weld.
Thanks all! No time today for fabing or working on adjustments. Storming over here in the E UP! Lots of wind, snow sometimes whiteouts. Then just wind. Lots for a old man to take care of when it stops! I have threatened to leave here cept after 70 years I'm either too dumb, or just smart enough to not sell off the homestead! WOrked outside for over 32 years in all kinds of weather, use to enjoy it lots! Funny, a guy gets a little older and things change!
   / shoe or not to shoe? #10
I've used/use three implements to clear snow on my mile long gravel driveway, mailbox area and year.
FEL bucket - tilt the bucket up and it will not dig in.
3-point mounted blower - same as the bucket - tilt the cutting edge up
Rear blade - if the driveway is still soft - reverse the blade. Otherwise - use offset and angled in normal configuration.
New/Unused SD Lanch 20x30 All Steel Carport (A57454)
New/Unused SD...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A58018)
2019 KENWORTH T680...
1995 NEWTON CROUCH PULL SPREADER (A57192)
1995 NEWTON CROUCH...
2011 Ford F-550 ETI ETCMH37IH 37ft. Insulated Material Handling Bucket Truck (A55973)
2011 Ford F-550...
