Oil & Fuel Shire 354 / Jinma 354 overdue service
   / Shire 354 / Jinma 354 overdue service #1
JinmaSteve
Shire 354 (Jinma 354)
Just purchased my first tractor a 2005 Shire 354 (basically a Jinma 354) running a TY395I engine. Its been pretty much neglected over the last 10 years and I am not sure when it was last serviced. So the plan is to basically change a load of filters (air, oil, fuel, hydraulic lift) replace the oil and top up on the transmission and hydraulic fluids and check coolant - is there anything I have missed and what should I watch out for as I am doing this overhaul?
Its got a new battery and starts well, but the hydraulics on the FEL leak like a sieve so that's the next project after the service. Most of the electrics don't work either but the battery does appear to be charging just cannot do anything in the dark :)
One of the things I have noticed is that I cannot lift the hood unless the FEL is in the high position - is that common?
New to the forum and looking forward to having a play over the summer - may even try and build a new dash board since a replacement is over £300! - anybody actually replaced the dash board / gauges?
And finally in the UK (you may have noticed the spelling) and there appears to be no real support over here for Chinese tractors - which is a shame since I am really please with mine so far.
New issue identified, the PTO will not stop turning around even when its in "neutral" - anybody had this before?
   / Shire 354 / Jinma 354 overdue service #3
Hello, Do you still have the tractor? Where are you located.
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
Wright Sentar (A50120)
NEW Work Saver Skid Steer/Sub Compact Grapple (A53472)
NEW Work Saver...
Ryobi Compound Miter Saw (A51573)
Ryobi Compound...
