"Shimming" a 200cx loader
   / "Shimming" a 200cx loader #1
bxowner
Vermont
John Deere 5055e
Saw several comments about "shimming" a loader on a 790 to increase capacity. I'm wondering if there's a way to get some quicker dump cycle speed for the 200cx on my 2305... the thing is darn slow. Not interested in adding capacity, as it's plenty capable for lifting.
I'm also thinking ahead to the winter and how nice it would be to have a quicker response for snow removal - specifically dumping the bucket and rolling it back.
   / "Shimming" a 200cx loader #2
The "shimming" is done to increase pressure (PSI) which in turn increases lift capacity, it has NO effect on speed. To increase speed you must increase flow (GPM) and that cannot be "shimmed".
Pressure does the work, and the Gallons Per Minute determines how fast it get's done.
   / "Shimming" a 200cx loader #3
You might check to make sure the regen. function on the dual SCV is not locked out. There is info. about that in the manual.
   / "Shimming" a 200cx loader #4
You'r hitting on something I have been thinking about.
Increasing pressure will not increase the Gallons Per Minute rate at all. Is that right?
Just thinking now. My power washer is 2600 psi but the Gallons Per Minute from the water system does not go up when it is running. Good comparison?
   / "Shimming" a 200cx loader #5
I thought I made that pretty clear in my post above. The ONLY way to get more GPM out of these type pumps is to turn them faster...and that just is not feasible.
   / "Shimming" a 200cx loader #6
Sometimes I'm a little slow. Got it now. Thanks:)
   / "Shimming" a 200cx loader #7
since were on the subject, how hard is it to shim the pump and gain lifting force on the 200cx?
how much will it gain?
   / "Shimming" a 200cx loader #8
The shims go in the relief valve, not the pump!
   / "Shimming" a 200cx loader #9
It's not hard, and I think the 2xxxseries tractors do not even use shims like the 790's do, it's just a bolt with a jamb nut on it. You will NEED to buy a guage so you can check the pressure both before and after. There are lots of threads on this...
   / "Shimming" a 200cx loader #10
ah thanks for the info.
I know nothing about these hydraulics!
I'll search it! :cool:
UNUSED LANDHONOR LHR-EPC40 PLASMA CUTTER (A54757)
UNUSED LANDHONOR...
2002 JOHN DEERE 450H CRAWLER DOZER (A51406)
2002 JOHN DEERE...
CONTACT INFO LOT NUMBER 6 (A53084)
CONTACT INFO LOT...
2025 Single Cylinder 40in Grapple Rake Mini Skid Steer Attachment (A53421)
2025 Single...
CRAFCO INC. MAGUM PORTABLE SPRAY INJECTION PATCHER (A54756)
CRAFCO INC. MAGUM...
1969 Jeep 4x4 (A54865)
