Shim kit for jd 3032e
   / Shim kit for jd 3032e #1
Drbrockhoeft
Abita springs, La
John deere 3032e
Hello, I'm new here and just recently purchased a jd 3032e. So far i am very please with the tractor and have had no issues. However, I would like to be able to increase my FEL lifting capacities. I've been having a hard time finding a shim kit for a 3032e. Does anybody know if a shim kit exists for a 3032e or if there is any other way of turning the hydraulics up a little bit. Thanks
   / Shim kit for jd 3032e #2
Relief valves are installed at the factory for a reason. Increasing relief valve could void the machine warranty.
   / Shim kit for jd 3032e #3
The answer is yes, there are shims to adjust the relief pressure, but the purpose is to adjust for weak springs.
or
An adjusting nut.
Check your settings, they might be low.
   / Shim kit for jd 3032e #4
Have you even tested the pressure yet? Most JD's don't use a "shim kit", but rather a bolt/jam nut type setup to adjust the PRV.-not sure what the 3038 uses.
I havnt checked the pressure yet. I'm not really sure how to. Also where is the adjusting nut located? Thanks
Thanks for the video, I have plenty of ballast so that shouldn't be a problem (rear tires filled and cutter). I just need a couple hundred lbs of extra lift for loading and unloading round bales of hay on and off a trailer. The FEL almost picks them up now. It just needs a little extra boost
   / Shim kit for jd 3032e #8
Did you figure this out? Need to do mine too. It just needs a little more so I can pickup my 1100lb generator.
John Deere 370 Flail Mower (A50860)
John Deere 370...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
Ford Super Duty 8ft. Truck Bed (A49346)
Ford Super Duty...
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
1990 International 4900 Fire Truck (A50860)
1990 International...
PENDING SELLER CONFIRMATIONS (A51219)
PENDING SELLER...
