Shiitake Growing On Logs
   / Shiitake Growing On Logs
How long does the wax stay liquid in the tube?
Because I keep the wax right up close to the temp that will deform the turkey baster plastic, I only keep the hot wax in it long enough to do a line of holes. When I finish waxing a line, I push the valve open against the side of the wax pot and squeeze out the remaining hot wax and hang the baster on a fork shaped holder I put next to the pot. That way, I always have the hottest wax possible. I also have a hanger like that for my inoculation tool, drill, and air nozzle (for blowing the drill chips away).
I have the log on two carpeted rails. When it is set and wedged so it won't roll, I do a line of drill holes. Then I fill the line of holes. Then I wax them. Everything involved is within arm's length.
Once I am able to find a stainless steel or glass baster, I will set up my waxing tool hanger to hold the tip of it right in the hot wax.
71065 (A49346)
71065 (A49346)
2016 MACK GU713(INOPERABLE) (A50854)
2016 MACK...
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
2007 CAT 904B (A47384)
2016 Ford Escape 4x4 SUV (A50324)
2016 Ford Escape...
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
