Shifting problem on 1987 Case IN 245
   / Shifting problem on 1987 Case IN 245 #1
butchtaylor
Case Intl. 245
Hi all.... My neighbor has a problem with his 87 case IN 245. It shifts as if the fork fingers are not in the correct place.
This tractor is 4 wheel drive with 3 ranges for speed and a three speed transmission. Anyone have a idea as to what may have happened. It did it all the sudden with no apparent noise when it happened.
Thanks in advance! Butch
   / Shifting problem on 1987 Case IN 245 #2
this won't help you much, but I just spent 2 grand putting a new clutch and shifting fork in my IH 255, and I'm told this is not unusual, particularly if the tractor was not shed kept or out of the weather. The shifting fork and pressure plate on mine were rusty and a mess, with major wear on the fork, had to be replaced. That may have been the only problem but once the tractor was split in half, it made sense to change it all out. I kept the old clutch which wasn't badly worn after 1000 hours. Anyone have a need for it?
Drew
   / Shifting problem on 1987 Case IN 245 #3
here's a pic of the worn shifter fork from my 255. New fork, new clutch, tractor runs like a dream. The fork looked like it worked its way over a little, didn't line up properly, and constantly wore metal off. Why, I have no idea.
But for a tractor with only a 1000 hours, this seems like a weak part to me.
2012 GALLEGOS 130 BBL STEEL VACUUM TRAILER (A58214)
2012 GALLEGOS 130...
2014 Freightliner M2 106 5.1Yds Asphalt Pot Hole Patcher Truck (A56858)
2014 Freightliner...
202480 (A54757)
202480 (A54757)
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A57192)
2008 INTERNATIONAL...
(1) HD 27ft x 24ft Full Garage Kit Metal Building Frame (A57453)
(1) HD 27ft x 24ft...
