Shifting kubota utv 900
   / Shifting kubota utv 900 #1
m38a123
Kubota utv 900
I have a kubota utv 900. Can only shift between low. Medium. High. Reverse if engine is not running?
   / Shifting kubota utv 900 #2
Do you pull the knob on the dash that relieves the pressure so it shifts easier? Sometimes I would have to shift by body forward/back to ease the shift too. Some people have installed a "coast valve" that might help.
   / Shifting kubota utv 900 #3
It helps to be on flat ground, and have coasted to stop rather than using the brakes.
They are touchy about the shifting.
   / Shifting kubota utv 900 #4
Jack the rear tires up off of the ground, shift to 2 wheel drive, park brake off, start the engine, and put the transmission into gear. Does one of the rear tires spin? If one does, you need to adjust the hydrostat linkage.
There also is a dump valve for the hydro that is connected to the brake linkage. Depending on the production year it can be on the LH or RH side at the rear of the transaxle. It may be stuck or out of adjustment. To shift and RTV, you have to depress the brake pedal fully, which activates the dump valve. A properly adjusted and functioning RTV should shift quite easily.
2012 Ford Focus Sedan (A56859)
2012 Ford Focus...
2841 (A58376)
2841 (A58376)
1990 TRAIL MASTER  TRANSPORT TRAILER (A58214)
1990 TRAIL MASTER...
2022 Wacker Neuson PDT2A 2in Portable Diaphragm Pump (A55851)
2022 Wacker Neuson...
Unused 78" Bucket Attachment (A55272)
Unused 78" Bucket...
2019 MACK GRANITE (A58214)
2019 MACK GRANITE...
