Shifting into Low Range
   / Shifting into Low Range #1
helobubba
I have a 3054 and often have difficulty putting the tractor in low range. I never have a problem switching into high range.
When switching ranges, I have the tractor out of gear, on level ground, and in neutral on the shuyttle shift. Any suggestions other than to call the dealer?.
   / Shifting into Low Range #2
What I do-
I leave tractor in gear on the main transmission, tractor stopped, shuttle in safe direction and clutch pushed in. I then barely feather the clutch as I shift. Works every time, no grinding. The shift between hi-lo range is not synchro and the gears need help lining up. An old 4-wheel habit.
Miklos
AGT Mini Excavator Attachment Set (A50123)
AGT Mini Excavator...
UNUSED WOLVERINE 66" BOLT ON PALLET FORKS (A51248)
UNUSED WOLVERINE...
2020 INTERNATIONAL LT625 DAY CAB (A53426)
2020 INTERNATIONAL...
2005 Ford Taurus SE Sedan (A51694)
2005 Ford Taurus...
Engel 20' Boat (A50121)
Engel 20' Boat...
UNUSED FUTURE FT36CJ STAND ON SKID STEER (A51247)
UNUSED FUTURE...
