Shift on the fly 180 D
   / Shift on the fly 180 D #1
BC Dave
Van - S Cariboo; BC
Yanmar YM180D
Morning Folks:
This may be a silly simple question ...BUT;
The 180D Operators Manual reads that, you shouldn't shift on the fly.
So if you want speed; you start out in 4 high? Opposite to a manual car transmission ...
Can you shift without grinding gears in high? If your at the right RPM's range it shouldnt hurt anything; right??
If so why cant you shift on the fly? It has a clutch; so why not?
Cheers BC Dave
   / Shift on the fly 180 D #2
Because it does not have a synchromesh transmission.
If you practice at it, you can get pretty good at shifting at just the right moment without grinding.
   / Shift on the fly 180 D #3
If you don't shift at the correct time , you could chip or break a gear. If it doesn't have power shift . I would stop & change gears
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A51692)
2017 Ford F-150...
Rhinox Mechanical 40 mm Coupler (A52384)
Rhinox Mechanical...
2015 Ford F-550 4x4 Wrecker Tow Truck (A51692)
2015 Ford F-550...
2012 Buick Enclave Premium SUV (A53117)
2012 Buick Enclave...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54313)
2016 FREIGHTLINER...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A53473)
2016 Ford F550 4x4...
