shield for back wondow
/ shield for back wondow #1
johnvickl
Kubota 7040 cab mowing with 15' batwing,
rock flew up broke both windows. 500.00
hicky. Want to make a shield so it won't happen again. Anyone have any ideas that will work amd look good, thanks John
/ shield for back wondow #3
I built mine from what I had lying around. First I measured the window so that the guard would actually rest on the frame and not on the glass. Next I built a frame out of angle iron. Now weld some mesh on the inside of the flat part of the angle. What you have now looks like a picture frame with the mesh being where the picture glass would be. On the top edge I welded some short lengths of tube to match up with the hinges on my tractor window. To install it I just loop some wire through the tube and around the back of the hinges, not pretty but easy for one man to do. Doing it this way lets the frame rest against the window frame and keeps the actual mesh away from the glass. Paint it flat black so there is no glare from the sun on it.
Thanks for you help
/ shield for back wondow #5
It doesn't have any windows yet but here's a photo of mine. It was a right of way mower for a power company, saw lots of action and saved a lot of headaches or worse and has the scars to prove it.
/ shield for back wondow #6
My dealer suggested I build a expanded metal guard starting just below the lower window back to the edge of the fender. This would be almost horizontal and held on with pins. the idea was to only run it when you needed it and not hamper the rear window opening.
Guess I better get mine made before I have to spend $500- on glass !
E/S
Street Sweeper (A60352)
Street Sweeper...
2016 Ford F-150 Ext. Cab Pickup Truck (A61573)
2016 Ford F-150...
2013 Ford F-150 Ext. Cab Pickup Truck (A61573)
2013 Ford F-150...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
2024 DEVELON DL250-7 WHEEL LOADER (A63276)
2024 DEVELON...
2014 Mitsubishi Outlander (A61574)
2014 Mitsubishi...
