Shibaura tractor (unknown everything)
   / Shibaura tractor (unknown everything)
It has four injectors a four glow plugs. 93FD385F-D915-45E3-B8F5-7E80AE9D5BB4.jpeg
I have been wrong before. Lol
Thank you !
   / Shibaura tractor (unknown everything) #14
Does it run? What repairs/maintenance do you need to do to it?
It runs fine trying to do maintenance on it it has been sitting for a while. Jurying to find reference material and could not find anything under S 2000 nor with the block numbers. Completely new to this realm so basically starting from scratch
   / Shibaura tractor (unknown everything) #16
Shibaura's have a reputation for being well made tractors. I have had 2 - a 15hp Shibaura and a 40hp New Holland (Made by Shibaura). Both bullet proof.
Step 1 Contact Sheaffer Tractor
Step 2 Change all the Fluids and Filters
Step 3 Power Wash that Beauty
Am I correct 4 cylinder engine.
That’s great thank you for all your time for responding. Felt lost on it all until this site
   / Shibaura tractor (unknown everything) #19
Welcome to the forum!
The label photo shows IHI-Shibaura. This combination shows to have began in the 1950’s. In a quick search I did not find when a name change happened again but did find reference to projects with Ford (later New Holland) and also with Yanmar for the AF series of tractors.
Can you get a number off of your oil filter and cross reference it.
Air filter can probably be matched either by cross reference or careful measurements to length and diameter.
In an external hydraulic filter-cross reference is probably best route. Not all models have an external hydraulic filter and even most imports have a cleanable suction screen that is removable and reusable. A huge caution these screens are located low in the hydraulic reservoir so expect a huge fluid dump if not drained first. Follow the suction hose(s) from the pump, the cover plate will be opposite the suction hose on the differential.
I am sure there is info out there, but if a limited gray brought to the US, it may be difficult to locate.
   / Shibaura tractor (unknown everything) #20
It is for sure a 4 cylinder - just a slightly smaller frame than I would have thought. You will have a nice tractor when it gets a little TLC.
How many speed transmission does it have?'
Does the 3 point hitch work?
Does the PTO work?
Does it have rear hydraulic connections?
Here is some interesting info about Shibaura Shibaura | Tractor & Construction Plant Wiki | Fandom
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
2007 Ford Edge SEL SUV (A50324)
2007 Ford Edge SEL...
1997 MONON 102" X 53' T/A VAN TRAILER (A51243)
1997 MONON 102" X...
UNUSED JCT QUICK ATTACH BACKHOE DIGGING ARM (A51244)
UNUSED JCT QUICK...
E-Z TRENCH GROUND SAW (A51244)
E-Z TRENCH GROUND...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
