Shibaura SU1341 - a few questions
   / Shibaura SU1341 - a few questions #1
davesisk
Platinum Member
Raleigh, NC USA
Massey-Ferguson MF 1220
Hey folks:
As I understand it, the SU1341 does not have a standard 540 PTO and has some sort of 2-pt hitch that can be converted to 3-pt hitch without too much difficulty. Many of these seem to come with the Shibaura 2-pt tiller. These seem to sell at quite a discount since it's missing the standard PTO.
So, here's a few questions. Does anyone know the hydraulic flow/pressure from the onboard pump? I'm assuming it's enough to run a loader...is it enough to run a small backhoe (like in 4-6 gpm)? Obviously, you can't use a PTO pump since it's doesn't have a standard PTO. Does anyone know if, after converting the 2-pt hitch to a 3-pt hitch, that leaves you unable to use the 2-pt tiller, or is that dependent on how you do the conversion? Any other thoughts on the SU1341 as a economical loader/mini-hoe/tiller runnin' machine?
TIA!
Dave
   / Shibaura SU1341 - a few questions #2
I believe that the pto on that model also turns backwards making it useless for anything but the tiller. Sorry, don't know much else about it.
Dur
   / Shibaura SU1341 - a few questions #3
I would build a subframe for the backhoe. It would have enough pressure to run a backhoe & probably enough gpm for a small hoe. To change back & forth between tiller & 3 point may require removing the tiller mounting bracket.
2022 K-Z Sportsmen 260BHSE 28ft T/A Travel Trailer (A48082)
2022 K-Z Sportsmen...
2022 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A48081)
2022 Chevrolet...
2015 Hamm H7i VR-3 Single Drum Vibratory Soil Compactor (A49346)
2015 Hamm H7i VR-3...
2019 John Deere 333G Skid Steer (A50657)
2019 John Deere...
2022 GMC Acadia SUV (A48082)
2022 GMC Acadia...
UNUSED Portable Bathroom and Shower (A50860)
UNUSED Portable...
