Shibaura SU1341 - a few questions
   / Shibaura SU1341 - a few questions #1
davesisk
Platinum Member
Raleigh, NC USA
Massey-Ferguson MF 1220
Hey folks:
As I understand it, the SU1341 does not have a standard 540 PTO and has some sort of 2-pt hitch that can be converted to 3-pt hitch without too much difficulty. Many of these seem to come with the Shibaura 2-pt tiller. These seem to sell at quite a discount since it's missing the standard PTO.
So, here's a few questions. Does anyone know the hydraulic flow/pressure from the onboard pump? I'm assuming it's enough to run a loader...is it enough to run a small backhoe (like in 4-6 gpm)? Obviously, you can't use a PTO pump since it's doesn't have a standard PTO. Does anyone know if, after converting the 2-pt hitch to a 3-pt hitch, that leaves you unable to use the 2-pt tiller, or is that dependent on how you do the conversion? Any other thoughts on the SU1341 as a economical loader/mini-hoe/tiller runnin' machine?
TIA!
Dave
   / Shibaura SU1341 - a few questions #2
I believe that the pto on that model also turns backwards making it useless for anything but the tiller. Sorry, don't know much else about it.
Dur
   / Shibaura SU1341 - a few questions #3
I would build a subframe for the backhoe. It would have enough pressure to run a backhoe & probably enough gpm for a small hoe. To change back & forth between tiller & 3 point may require removing the tiller mounting bracket.
1997 Mercedes Convertible (A48082)
1997 Mercedes...
EVERYTHING SOLD AS-IS WHERE IS!! (A50775)
EVERYTHING SOLD...
Poly Tote Tank on Cart (A50860)
Poly Tote Tank on...
2006 GMC C8500 Altec AM547 50ft Material Handling Insulated Bucket Truck (A50323)
2006 GMC C8500...
2019 Allmand Light tower (A49461)
2019 Allmand Light...
2011 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A50854)
2011 TROXELL...
