Shibaura SD4000 Hydrulic Problems, Need Help
   / Shibaura SD4000 Hydrulic Problems, Need Help #1
ledalton
Jasper, Tx
Shibaura SD4000
Shibaura SD4000 with frontend loader. The frontend loader works fine, power steering works fine. It has one pump to work everything including the 3 point hitch that barely works. It used to work fine. I've changed both filters, flushed the system and changed hydrulic fluid twice in one week to make sure it was clean. The 3 point hitch has no power, it will go up without any load on it very slowly, but will not even pick up a 100 lb implement. Also, when it does come up about eight inches with a load, as soon as you use the frontend loader it will drop back to the ground. I don't think its the pump because the loader will pick up a full load of dirt without any problem. The power steering works. I have never dug into hydrulic controls before and can't find any diagrams or help locally on this tractor. I'm at a loss.
   / Shibaura SD4000 Hydrulic Problems, Need Help #2
If everything works except the 3pt and going by what you said what it is doing.
I would suggest that the 3pt valve is bad or the 3pt cyl seals are bad.
If you install a hyd gage in the flow path, and cause the 3pt cyl to max out, you should read relief pressure.
If you can't , something is leaking or bypassing.
I got it fixed. Pulled the hydrulic controls off and soaked it in carb cleaner over night, blew it out with 160 lbs of air pressure, filled it up with wd 40 and worked the up an down lever about fifty times and installed it. Works better then it has ever worked. I didn't even have to buy an O-ring.
   / Shibaura SD4000 Hydrulic Problems, Need Help #4
Don't know where the hydraulic filters are on my shibaura DD4000
2023 JOHN DEERE 8R370 LOT NUMBER 200 (A53084)
2023 JOHN DEERE...
2016 Kenworth T270 Truck, VIN # 2NKHHM6X1GM110171 (A51572)
2016 Kenworth T270...
SHOPBUILT 40FT FLARE STACK (A52472)
SHOPBUILT 40FT...
UNUSED FUTURE 20' BI-PARTING WROUGHT IRON GATE (A51248)
UNUSED FUTURE 20'...
2018 John Deere R4038 Sprayer (A53342)
2018 John Deere...
2020 CASE IH 110N LOT NUMBER 222 (A53084)
2020 CASE IH 110N...
