Shibaura SD3000 4wd
   / Shibaura SD3000 4wd #1
nuke
Bronze Member
Richmond, Va
I have my eye on a Shibaura SD3000 4wd, 1600 hrs with a new Bulldog Loader for $6,900. What'd ya'll think?
The tractor has 4 PTO ranges, 12 speed (4 range, 3 speed), 36 hp (30 PTO)
MODEL DRIVE HP* CYL LBS LENGTH WIDTH HEIGHT
SD3000 4 WD 36 3 3727 130" 60" 76"
SOLD AS IS WHERE IS BY A UN-KNOWLEDGABLE EBAY SELLER.
What should I look for while inspecting a used tractor? Other than kick the tires of course.
   / Shibaura SD3000 4wd #3
This tractor is older than the hills. I'd steer away if it were me.
Eugene
   / Shibaura SD3000 4wd #4
Eugene
   / Shibaura SD3000 4wd #5
</font><font color="blue" class="small">( .....What should I look for while inspecting a used tractor? Other than kick the tires of course. )</font>
IMO, there seems to be three basic ingredients in selecting, purchasing and owning a great grey market tractor that will serve you well for many years...and with a minimum of repairs and upkeep.
Find a seller. One who is established, with a lot, service department or a well equipped shop, office and a phone number (yellow pages). He should have several models in various HP ranges with implements available.
Even if you know very little about tractors, an honest dealer will walk you through everything, including your size, HP, implements and budget. A dealer with less integrity will capatilize on what you don't know.
Ask for references.
Select a model (regardless of the manufacturer) that is well supported and parts are, and will be available in the future. Can't think of anything much worse than a less popular model, built in limited numbers for 1 or 2 years. Even though it may serve you well for a few years, if anything "snaps" in the drivetraine, parts (used) will be VERY difficult to come by.
Reconditioned, Rebuilt, Refurbished tractors without any documentation are none of the above. They are just tractors assembled from salvaged parts, and made to run. Fresh paint, new hour meter and a new seat does not make a reliable tractor.
I hope this helps...Mark
   / Shibaura SD3000 4wd #6
Ask for references.
What years were these made? Aren't most of these tractors "older than the hills"?
   / Shibaura SD3000 4wd #9
Most are newer than this one. Most of the older Yanmars are at least 79 -83 models and have a pretty good following along with reasonable parts support. The Shibaura 3000 looks like something from a 50's Godzilla movie.
Eugene
   / Shibaura SD3000 4wd #10
Eugene
2019 FORD TARNSIT CONECT CARGO VAN (A52577)
2019 FORD TARNSIT...
2018 CATERPILLAR 299D2 SKID STEER (A51246)
2018 CATERPILLAR...
INOP/NON- RUNNING 2013 Ford F-250 Pickup Truck, VIN # 1FT7W2A61DEA38762 (A51572)
INOP/NON- RUNNING...
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2018 MDB LV600 GREEN CLIMBER SLOPE MOWER (A51406)
2018 MDB LV600...
