Shibaura SD3000 4wd - Clutch Problem?
/ Shibaura SD3000 4wd - Clutch Problem? #1
nuke
Richmond, Va
When I depress the clutch it does not engage and allow me to shift into gear. I checked the adjustment, all seems fine. Is this a clutch problem or can it be something else? Who/how/where can I get a clutch for this tractor?
/ Shibaura SD3000 4wd - Clutch Problem? #2
Hello Nuke,
I have a SD3000 I recently acquired with the same problem. I know your post on this subject is from a while ago, but I was wondering how you solved the problem. Any info would be greatly appreciated.
Thanks, Mark
/ Shibaura SD3000 4wd - Clutch Problem? #3
The clutch is most likely stuck to the flywheel. Put it in gear and drive or pull it around while hitting the brake pedels off and on and it should free up.
Eugene
Formerly buppy69
