Shibaura sd1800
/ Shibaura sd1800 #1
whamkabam
Wondering where a man might find a water pump for a shibaura sd1800. I dont know the year model. I live in North Ga. Any help would be appreciated.
/ Shibaura sd1800 #2
I think you can solve your problem by removing the water-pump on your tractor and take it to your nearest Ford Tractor Dealer, and they can cross reference it. You maybe able to get a rebuilt kit for the existing one, if you are a "wrencher;" a new one will require taking your checkbook with you! Ford was using Shibaura engines then, and I assume they still are?
I rebuilt one on my '82 Ford 1500, because a new one was $300.00, and that was a decade ago!! It isn't that difficult to rebuild, but check with them for the details on required tools that maybe necessary?
/ Shibaura sd1800 #3
"<#<"WaKaBam:">#>!!" The first water-pump on the Ford 1500 Shibarau engine (20 hp) lasted twenty years, and the rest of the components of the engine have never been a problem; however, if you run it out of fuel, it will be a (PITA) too! I do change the anti-freeze on the tractor more often than the others, that have had equal use, and with a higher concentration of anti-freeze for lubrication. The first water-pump lasted a couple thousand hours.
Also, welcome to this site, there is an infinite amount of talent here!!
UNUSED RAYTREE RMSC78 - 78" HYD SOIL CONDITIONER (A62131)
UNUSED RAYTREE...
2016 Ford Fusion AWD Sedan (A61569)
2016 Ford Fusion...
2024 BOBCAT T66 R-SERIES SKID STEER (A62129)
2024 BOBCAT T66...
2017 Ford Escape SUV (A61569)
2017 Ford Escape...
2018 CATERPILLAR D6T XL HIGH TRACK CRAWLER DOZER (A62129)
2018 CATERPILLAR...
2025 Grapple Hydraulic Mini Skid Steer Attachment (A61567)
2025 Grapple...
