Shibaura lek802d
   / Shibaura lek802d #1
pcat
Ford 1300, 8n, 801 power master
Hello, I have a ford 1300 4x4 that has the lek802d engine, one day while using it i heard a noise, and looked and saw oil leaking out of front of engine., which appeared
to be coming from the Harmonic Balancer, Has anyone ever had one of these come loose before? I don't know if something has broke on front end , or the retaining
bolt for (harmonic balancer) Crankshaft Pulley came/fell out, I assume it had one, not sure about now. anyone happen to know what size/length etc... this bolt should be? For Crank Pulley Bolt???
This tractor has been sitting for a few years since the oil leak happened, looking into trying to see what i need to find/fix to get it going again. By the way, after it happened, i was crazy enough to start it again, and it ran. don't know for sure, but figure if it was a busted crank it would maybe happen between the 2 pistons (would be my guess). Its been a long time ago, since this tractor failed on me, my PDF manuals i bought/aquired back then was in Sept 2013, so guess it has been a while.
Thanks.. Paul
   / Shibaura lek802d #2
The bolt that holds the harmonic balancer is SBA010331225 BOLT; M12 x 25. I lean towards the crank being broken.
   / Shibaura lek802d
ok, thanks for the informatoin, i'll respond back here if the new bolt fixes my problem or not! have a good one... Paul
Enmark Z Spray (A53316)
Enmark Z Spray...
2020 Ford Ranger XL (A53314)
2020 Ford Ranger...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A51691)
2010 Turfco...
Bigfoot Metal Stand Up Sign (A55758)
Bigfoot Metal...
Chains and Binders (A53316)
Chains and Binders...
2012 Jaguar XJ Sedan (A55758)
2012 Jaguar XJ...
