Shibaura LE892 rebuild or replace
   / Shibaura LE892 rebuild or replace #1
Geoff Nelson
ford 1700
HI i have a shibaura LE 892 1.3 lt tractor engine i am thinking of trying to swap out to another small diesel engine which i might be able to adapt to fit my ford 1700 tractor could they please advice me . The LE 892 is a two cylinder 25 hp. would use a larger capacity engine it possible.
Geoff
   / Shibaura LE892 rebuild or replace #2
Suggest checking and comparing part numbers for bellhousings clutches etc. for your model versus other Shibaura made Fords from around the same era to see if potential motors will bolt up to your drivetrain. Tractordata and Messicks' websites may be helpful here. The next model up 1710 had a 1.4L 3 cylinder. Adding a cylinder adds length which can cause issues with motor mount location, radiator clearance, etc. and depending on the displacement difference and your climate may need a larger radiator.
20 ft. Shipping Container (A53117)
20 ft. Shipping...
2019 CATERPILLAR 740GC OFF ROAD DUMP TRUCK (A52705)
2019 CATERPILLAR...
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A52705)
2017 CASE IH 580...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
New Holland 325 Manure Spreader (A55218)
New Holland 325...
