Shibaura D23 Front wheel drive engagement gears needed.
   / Shibaura D23 Front wheel drive engagement gears needed. #1
bshwhckr10ga
Cole Camp, Mo
Shibaura D23
I have a D23F. Currently the front wheel drive will not work. I have 3 bad gears. Engagement gear. Front drive gear and the in between gear. Does anyone know where to get these gears
   / Shibaura D23 Front wheel drive engagement gears needed. #2
West Kentucky Tractor Parts is my go to place for used parts. They don't show a D23 but they do show a number of Shibauras in stock. They may have a D23 and not updated it online or they may have a model that uses the same drive parts ( if you or they can figure out what crosses over between models???)
   / Shibaura D23 Front wheel drive engagement gears needed. #3
I have the same problem with my Shibaura SD2243. I hope you found your parts. Are the gears that you needed to replace all in the front end housing? Mine was making a clicking noise then the front drive stopped working. A mechanic at West Kentucky Tractor Parts told me he thought it would be a broken ring gear in front end housing. Just trying to see if I should go ahead and pull it out.
2007 CATERPILLAR 930G WHEEL LOADER (A51246)
2007 CATERPILLAR...
2007 Nissan Armada Multipurpose Vehicle (MPV) (A51694)
2007 Nissan Armada...
2022 CATERPILLAR 272D3 SKID STEER (A51246)
2022 CATERPILLAR...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2015 Peterbilt 337 Tilt Body w/ Dovetail (A52384)
2015 Peterbilt 337...
2023 John Deere 6R 155 MFWD Tractor (A53342)
2023 John Deere 6R...
