Shelterbelt
   / Shelterbelt #1
Wheatland KB
Cluny, Wheatland County, Alberta (east of Calgary)
Kubota L3400HST
I've been planning a shleterbelt around our 5 acre place since odering 1000 seedling trees in Feb. One row of chokecherrys around the perimiter, A row of hybrid polar inside of that, then a row of alternating white spruce and siberian larch on the inside of that. The trees were supposed to be here May 30 so I figgured I had lots of time.
I found out 2 weeks ago that the trees will be here on May 2.:eek:Not much time!
The ground hasn't been worked for around 30 years and is pretty hard as I tried to use the tiller in spots over the last few years and it was like tilling on a tennis court!!!!
I decided (through reading excellent posts on TBN) to build a subsoiler. I jambed a quick ripper together and tried it out two weekends ago. Worked not too bad but only went down about 4 inches.
Last weekend I added a gusset to the top link point that extended it about 8 inches. That tilted the tines forward enough that the little ripper dug in about 10 inches and worked the hard pan up pretty well.
Once that was worked up I put the tiller on and tilled like it was in butter. then it was time to relax.
I will be heading out for the weekend to till one more time and then plant 1000 seedlings on Saturday and Sunday. I will take some better pics of the goings on this weekend.
I hope the pics attach OK. The last two are just after trying the ripper the first time and it also gives a bit of a before moving all of the junk view.
   / Shelterbelt #2
Is it going to be a windbraker? Snow barrier? I am just curious about the typical problems you face in a country open like this.
   / Shelterbelt #4
Wish you well on your planting. The recent snow should provide some nice moisture for the transplants.
Neat subsoiler you rigged up. Custom made weights too I see!:D
   / Shelterbelt #5
nice pics. Not to get off your subject but i would love to see some more pics of that international dump truck. Thanks Taylor
   / Shelterbelt
I don't have many pics of the truck but will take more in a couple of weeks.
We did get the trees in last weekend. Started by giving the whole perimiter a final tilling. then ran the harrows over it all and rolled it all.
To make the planting easier we built a single shank row cultivator and ripped all of the rows. Then we planted the trees and were pretty much done in 1 day thanks to the Wife, Daughter and Daughter's Boyfriend.
Makes a big difference if the ground is prepped well.
A few more photos. Keep in mind all of the implements we are using are purpose built and done quickly so there was no time to make them look pretty.
   / Shelterbelt #7
Good show!:D
Seeing those farmland Fields in the background takes me back a few years.:D
2005 CHANDLER 500 BBL FRAC TANK (A53843)
2005 CHANDLER 500...
2023 G Bar K Skirted Hauler Bed (A55218)
2023 G Bar K...
2009 JLG 1930ES ELECTRIC SCISSOR LIFT (A51242)
2009 JLG 1930ES...
2007 Fontaine Trailer (A52377)
2007 Fontaine...
Toro Workman MDX Utility Cart (A51691)
Toro Workman MDX...
66'' root grapple (A53421)
66'' root grapple...
