Shell Rotella T4 SAE 10W-30 ALERT!
   / Shell Rotella T4 SAE 10W-30 ALERT! #1
mscheeer772
I have a JD 4310 with an e-power reverser and was wondering if I can use
the above oil for my engine
   / Shell Rotella T4 SAE 10W-30 ALERT! #2
No problem.
   / Shell Rotella T4 SAE 10W-30 ALERT! #3
I thought that something may be wrong with Rotella…..
click bait sorry
   / Shell Rotella T4 SAE 10W-30 ALERT! #6
Alert…… could use an oil waaay better. T4 is very mediocre 😉
   / Shell Rotella T4 SAE 10W-30 ALERT! #9
No idea where you are located. Look at the manual for viscosity vs operating temp range. 10w30 is for cold weather in most diesels. 15w40 for warmer weather.
Rotella is a good oil. T4, T5, T6. Good stuff, but look at the actual viscosity you need
   / Shell Rotella T4 SAE 10W-30 ALERT! #10
Every 200 Hours-JD 4310 oil/filter maintenance
Changing engine oil. Recommended engine oil type: Plus-50, SAE 15W-40, 10W-30, 5W-40. API Service Category CK-4, CJ-4, CI-4 PLUS, CI-4, CH-4. How much to fill: Engine Oil Capacity - 4.3 L (1.14 gal). After completing the filling procedure, check motor oil level.
Ambient temperature isn’t much of a concern if oil used is a good synthetic. Most of the hd diesel engine manufacturers in the past 5 years have been recommending 10w30…
20304 (A51694)
20304 (A51694)
2020 Kubota RTV-X1100CW-A (A47384)
2020 Kubota...
Homemade Flatbed T/A Tilt Trailer (A50323)
Homemade Flatbed...
New Holland Boomer 55 Tractor (A52384)
New Holland Boomer...
2011 Ford F-450 Crew Cab Omaha Service Truck (A50323)
2011 Ford F-450...
2018 International WorkStar 7400 T/A Dump Truck (A50323)
2018 International...
