Shelf life of unopened UniversalHydraulic/transmission fluid ?
   / Shelf life of unopened UniversalHydraulic/transmission fluid ? #1
dennis52
Queensland Australia
Kioti DS4510HS , Kubota B7100
There is currently a special on Gulf Universal hydraulic/transmission oil so I changed my oil today but thought I might buy two more 20 litre buckets for the next change which will be due in about 30 months.
Does this type of oil deteriorate with time?
   / Shelf life of unopened UniversalHydraulic/transmission fluid ? #2
It will be fine. I would just turn the pail upside down 24 hours before you use it.
Chris
   / Shelf life of unopened UniversalHydraulic/transmission fluid ? #3
You won't find much consistent information on this. Possibly the wide variation in storage conditions makes them cautious. Best answer is to write the manufacturer. The longest I have seen in print is five years unopened and properly stored.
   / Shelf life of unopened UniversalHydraulic/transmission fluid ? #4
I wouldn't think that an air tight bottle or can would ever deteriorate if kept in a shady or dark area where temps were not too hot. I don't think cold would be an issue. Heck if a Twinkie bar is good for 50 years, oil should for sure be ok. I know I had food(C ration) from 1949 served to me when I was in the army in 1970 which was packaged in air tight cans.
   / Shelf life of unopened UniversalHydraulic/transmission fluid ? #5
I asked an oil guy once.. He said it comes from Dinosaurs so and that was millions of years ago, so whats 20 years on a shelf.
not sure how I felt about that response.
   / Shelf life of unopened UniversalHydraulic/transmission fluid ? #6
All depends on if the container is sealed and moisture conditions.
   / Shelf life of unopened UniversalHydraulic/transmission fluid ? #7
The oil will have additives that will settle to the bottom. How long that takes I can't say. Like Diamond Pilot said, turn it up side down over night, roll it down a hill, some other way to shake it up and you'll be fine. I've taken a 5 gallon bucket to my local hardware store and had them put it on the paint shaker for 5 minutes.
   / Shelf life of unopened UniversalHydraulic/transmission fluid ? #8
Snow plow oil and brake fluid has a water absorber in it that becomes saturated over time as plastic isn't a perfect vapour barrier but other than that we use old sealed oil all the time.
Come to think of it , at the end of the pour of the "fresh" out of the store pails of oil that I filled up with this week, I found sediment. At the time I thought it must have been foaming I was looking at.
Anyway I poured it all in .
Maybe it's already old that's why it's discounted.
No manufacture date on the pail. Certainly no instructions about shaking up the oil.
   / Shelf life of unopened UniversalHydraulic/transmission fluid ? #10
Turn it upside down for a day or two and be good to go.
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50322)
Pitts Tri-Axle RGN...
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A50459)
2000 TRAILKING...
FRONTIER WR3210 LOT IDENTIFIER 108 (A53084)
FRONTIER WR3210...
ECHO SRM-2120 GAS WEED EATER (A51248)
ECHO SRM-2120 GAS...
2017 JOHN DEERE 6120M TRACTOR (A51406)
2017 JOHN DEERE...
UNUSED JCT 84" HYD DOZER BLADE (A51248)
UNUSED JCT 84" HYD...
