Shelf life of antifreeze
   / Shelf life of antifreeze #1
jim2210
NE PA
JD 2210
I just changed the antifreeze in my JD2210 with the Cool Guard 50/50 pre-mix. Since my radiator only holds about 3 qts., I have enough left over to do about 4 or 5 more changes. Since my manual says to change every 2 years (antifreeze label says it's good for 5 years), it will be sitting a while. How long will the unused antifreeze last before going "bad"?
   / Shelf life of antifreeze #2
I have always been told the life is only limited on the antifreeze in the engine. Due to corrosion inhibitors and lubricants breaking down.
I always put in the 5 year stuff when I change it.
   / Shelf life of antifreeze #3
Hiya,
I would wager that the label says it's good for 5 years of freeze protection w/ the anti rust additives depleted far before that. Sitting in a sealed container on the shelf, I would say it's good for at least the 5 and most likely far longer.
I hope the latter is the case as I'm still working off the 10 cases I bought at an auto parts auction in the 80's, seems to work just fine after almost 30 years.
Tom
Thanks for the replies. Well, it sounds as if I can get a few more changes before I have to worry about anything. Maybe the extra laying around will motivate me into changing more often. Thanks again!
   / Shelf life of antifreeze #5
tomd999 said:
Hiya,
Tom
Actually, the antifreeze never wears out (or loses its antifreeze capabilities). They have a special inhibitor pack that does last five years, plus the long life antifreezes don't have silicates, which is one of the main reasons to change ordinary antifreezes. If you don't change ordinary antifreezes, the silicates start to drop out, and this can really plug things up. At least that's my understanding of it.
2005 Dodge Caravan Van (A54815)
2005 Dodge Caravan...
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51692)
2001 Dodge Ram...
2012 Nissan Rogue (A50324)
2012 Nissan Rogue...
UNUSED LANDHONOR MAP-16-24W MINI MOUNT PLATE (A54757)
UNUSED LANDHONOR...
JOHN DEERE XUV835M LOT NUMBER 25 (A53084)
JOHN DEERE XUV835M...
