Sheesh.. Changing a headlight
/ Sheesh.. Changing a headlight #1
PhilNH5
Platinum Member
SE NH
Kubota B3000HSDCC
My headlight burnt out. I drive a Dodge Dakota quad cab.
After checking the manual I went out and picked up the lightbulb.
Once back home I started the replacement process. The manual was short and useless. First I needed a Torx driver. After un-doing that I needed a large flat screw driver to undo the quick connects to the turn signal unit. There was no slack in the wires so I used the screwdriver to pry off the connectors. I could then remove the turn signal unit.
Next I had to remove the headlight and its' housing. This required a 10 mm socket and 10 inches of extensions to reach the 3 nuts. What a pain. I replaced the bulb and then re-assembled eveything.
In all it took about forty minutes. If I didn't have a Torx set and extensions for my socket set I would have been stymied. Changing a lightbulb should not be so hard.
The conspiracy theorist in me thinks they do this by design so the average owner will take it into the shop to get replaced.
Phil
/ Sheesh.. Changing a headlight #2
It's amazing how complicated the simplest repair has become. I recently had to change a tail light on my Ford F250. I had to read the manual several times to even understand what they were saying, and it wasn't even accurate. What used to be a 5 minute repair, now takes about 20. I don't even want to think about when a headlight blows in one of my trucks.
I used to do most of my own repairs on my trucks, now even changing a bulb is painful!!!
/ Sheesh.. Changing a headlight #3
After making the same mistake with several Fords, I finally noticed that most Ford taillight assemblies have all kinds of nuts and fasteners on the back. However, if you look close, there will usually be 3 that are different and longer. Loosen those 3 and the assembly pops out in a minute. The other fasteners hold the rest of the housing and backing plates in place. You don't need to remove all that stuff. One of my construction workers needed a taillight bulb. I had one in my glove box and changed it for him in less than 2 minutes with only a pair of slip joint pliers. He was about to make the common mistake of undoing 6+ nuts and brackets and yanking back all the trunk liner material.
/ Sheesh.. Changing a headlight #4
A couple of weeks ago, I had a left rear turn signal bulb went bad on my 2001 Ranger, and I guess maybe I was just lucky; a philips screwdriver and a few minutes were all that was requiired. The bad part to me is that I went to AutoZone for a bulb and naturally they only come two bulbs together, and of course, made in China, and cost over $4 for the pair and I used one and will probably lose the other one before I need it.
/ Sheesh.. Changing a headlight #5
The second bulb is so that you can be a good samaritan. See previous post.
/ Sheesh.. Changing a headlight #6
i always put the extra in a place i know I will always remember that it is. and when i need another i remember doing that but i never remember where.
/ Sheesh.. Changing a headlight #7
Me too. But don't worry, you will find it right after you buy and install another one.:)
/ Sheesh.. Changing a headlight #8
A friend of mine has a Chrysler of some sort, the battery is located in such a manner that the front wheel and fender liner access door must be removed in order to change it.
/ Sheesh.. Changing a headlight #9
Tell me about it. I jsut assembled my new big snow blower. Last step - reduce pressure in tires to 15-17 psi. UHUH. I am the proud owner of two gauges, bought the last one last summer and put "where I can find it". Still amongst the missing.
Harry K
/ Sheesh.. Changing a headlight #10
Buy 2. Leave the crappy one out and someone will 'borrow' it and put the good one where you 'will find it later'. Then go find the neighbor with the crappy one when you need it.
/ Sheesh.. Changing a headlight #11
heck i thought i was the only one:D i have a box of bulbs and most of them will still be there when i pass on, always forget about them and then like BIRD I GO buy 2 more, .:(
/ Sheesh.. Changing a headlight #12
Lights are odd... changed the headlight on the passenger side of a 19 year old car three times... driver side is still original... same with side marker lights... some changed three or four times while others are original... New house lights... some changed many, many times while others are still the original bulbs...
mark
/ Sheesh.. Changing a headlight #13
Yes, I have 2 lights on my front porch that I installed after Katrina in 2005. Each one has three 3 watt flicker bulbs in it and 5 are original bulbs and I have replaced one four times. Last week I changed it and it burned out 3 days later. Even if a socket was bad it doesn't seem like it would burn out a 3 watt light. And bulbs are about $3 each.:mad:
/ Sheesh.. Changing a headlight #14
My 97' Dodge Ram is easy once you change a headlight the first time.
You just twist the plastic ring and the assembly pops out of the back of the headlamp housing. Unplug the old, plug in the new and pop it back in.
The trick is to do that by feel only because once you have your arm in there, you cannot see what you are doing.
/ Sheesh.. Changing a headlight #15
That's the same way most of our Chevy's are.
/ Sheesh.. Changing a headlight #16
" The trick is to do that by feel only because once you have your arm in there, you cannot see what you are doing."
Same way with my Pontiac Vibe. And on the Driver's side I can barely squeeze my hand in the space.
Anyone else notice that you're having to change headlights more often with newer cars. Maybe it's the daytime running lights. The headlight bulbs on my 2005 Vibe burn out every 6 months.
WVBill
/ Sheesh.. Changing a headlight #17
That's so they can charge an hours labor to do it at the dealership... IE.. 60$ to change a 5$ lamp...
soundguy
Phil
1999 FREIGHTLINER FLD70 ROLLBACK (A65643)
1999 FREIGHTLINER...
2016 International DuraStar 4300 Dump Truck (A64556)
2016 International...
Timpte Hopper Bottom (A63689)
Timpte Hopper...
New/Unused Landhonor Pallet of Chains and Binders (A65583)
New/Unused...
(2) 18x38 Rims (A65640)
(2) 18x38 Rims...
2018 VANGUARD REM VXP 53FT T/A DRY VAN TRAILER (A59914)
2018 VANGUARD REM...
