BigSteve63
Bronze Member
Planning on 12 x 16, 9' sidewalls, and either an 8/12 or 12/12 gable roof with a gable dormer for light (or maybe just a skylight) Thinking of 8' overhead door on one end, 1 walkout door, and a 36" x 36" window that I had left over. Pics look great- really like the french doors. Does it have lots of overhead room?that was the biggest mistake i made and its a biggie. there are blocks at each corner and the middle for a total of 6. I bought this book and took my design for the blocking straight from it, rrrrrrr i not happy. floor bounces and there has allready been some sag from the middle to the corners. I have several 16 foot bridge tembers that i plan on suporting it with if it gets any worse.
the plans also said nothig about cripples between the floor joist and those need to be there also uggg live and learn. I have built many decks and never had a problem, should have went with what i knew not what a book said.
each block has 12" of compacted pea size gravel under it along with a 12x12x1.5 concrete paver then the blocks are on top of that. The reason i used this type of foundation is so that i could avoid a permit due to im very close to neighbors fence and various other reasons. with the structure not attached to the gound we can build whatever whereever. If i had the $ and was going to do it all over again i would set post in concrete 24" deep and build from that.
how big are you going to build yours?
