Shed roof not hooked to building
   / Shed roof not hooked to building #1
Ed of all trades
Elite Member
Waynesboro Va
John Deere X310, JD LA 145
Thinking of building a tractor - equipment shed that has a shed roof that just goes down a slight hill with not much pitch to the roof. Anyone tried this in the days of building codes? My dad built one over 50 years ago and it worked well.
   / Shed roof not hooked to building #2
Unless you live in a HOA, I don't think codes have much to do with it.
In areas where the snow load is high, the amount and size of the roof rafters/joists needed to carry the weight on a low-pitched roof is expensive, compared to trusses with say a 6/12 pitch.
   / Shed roof not hooked to building #3
My tractor sits in a shed attached to a 35 foot prefab building I use for a workshop. It's got 6" posts at 8 foot spacing with dual 2-by-12's at the top and 2-by-10's as rafters on a 20" spacing. Rafters rest on 2-by-10 bolted to shed every 4 feet. (Was given most of the lumber in a fluke deal) The shed and workshop are on a slight hill with the shed floor about 8 inches below the ground under the shop. The shed roof drops about 4 inches in a 9 foot span and has withstood several snows topping 24 inches without a problem. I did not check any codes before doing it, and don't thing you have to for small ag buildings here in the Valley... Or so the county folks said.
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A52748)
NEW HOLLAND 706 30...
2018 FORD TRANSIT T150 CARGO VAN (A52577)
2018 FORD TRANSIT...
2017 KOMATSU  D61 PXI-24 (A52472)
2017 KOMATSU D61...
Toro Mower (A50324)
Toro Mower (A50324)
2014 Jeep Compass Multipurpose Vehicle (MPV), (A51694)
2014 Jeep Compass...
KARCHER WALK BEHIND FLOOR SCRUBBER (A52472)
KARCHER WALK...
