Shed for storing diesel. Cheap floor that will contain spills.
   / Shed for storing diesel. Cheap floor that will contain spills. #11
Yeah. We had a 175 or 250 gallon (don't know which) fuel oil tank in our finished basement in NJ. I buried that size tank in the back yard for our diesel cars. Guess it's still there, probably collapsed now.
   / Shed for storing diesel. Cheap floor that will contain spills. #12
Set the barrels in 275 gal plastic totes with the top cut out
   / Shed for storing diesel. Cheap floor that will contain spills. #13
New Pig also carries containment pallets
link is for a two drum unit for $226
   / Shed for storing diesel. Cheap floor that will contain spills. #14
I’d use plastic barrels. Metal barrels get rust in the fuel.
   / Shed for storing diesel. Cheap floor that will contain spills. #15
Nearby was a stone house that had 3 oil tanks in the basement area.
Three since the deliveries were not feasible during winter.
A fire occurred while a sitter was caring for 6 children and the sitter panicked and ran for neighbor help rather than remove the kids.
All six perished and were totally incinerated.
The end effect was like a crematorium.
They would’ve probably died anyway with or without the fuel.
   / Shed for storing diesel. Cheap floor that will contain spills. #16
Plastic kiddie pools work in a pinch. Put the barrels on piece of plywood so it doesn't poke a hole in the plastic.
   / Shed for storing diesel. Cheap floor that will contain spills. #17
Many house fires with fuel tanks in the basement most of the time are still full of fuel when the fire is out.
The fuel will support combustion but is really quite safe.
Most horror stories are just that stories.
   / Shed for storing diesel. Cheap floor that will contain spills. #18
I used a 30 gallon oil barrel setting on wood since 2007, absolutely no issues. This year I upgraded to a 55 gallon and set it in this. Wouldn't "contain" 55 gallons but like I said, the 30 gallon had no obvious corrosion in 14 years. I love this cart as it moves very easy on concrete and will keep the barrel bottom clean and off the floor. Bought it from Northern Tool.
   / Shed for storing diesel. Cheap floor that will contain spills. #19
How about building a plywood "sand box" type base set up on blocks off the ground. Maybe 4' square, by 2x6 deep, with additional joist... Fill with sand. Cover with a slotted floor so any spill will go into the sand..
Build shed walls, roof, door around the sand box platform... Or on skids if you want, need to move it..
   / Shed for storing diesel. Cheap floor that will contain spills. #20
just how many hundred years are you expecting to use those same drums?
You will leak and drip infinitely more in the fueling and filling process than the drums will ever leak in the first two hundred years anyway.
As for sand. So NOW you have contaminated sand. What are you going to do with that? Send it to a facility for SAFE disposal?
New 27ft Ratchet Strap (A54865)
New 27ft Ratchet...
2021 Hyundai Elantra SEL Sedan (A55758)
2021 Hyundai...
2019 GEHL R105 WHEELED SKID STEER (A51242)
2019 GEHL R105...
2018 JLG T350 PORTABLE ELECTRIC MANLIFT (A52706)
2018 JLG T350...
(NEW) 2022 Greenworks CU400W Commercial Work Utility Vehicle (A55302)
(NEW) 2022...
Advance SC750 28in Floor Scrubber (A53421)
Advance SC750 28in...
