Sheathing and Birds Mouth on Rafter
   / Sheathing and Birds Mouth on Rafter #1
WVH1977
Platinum Member
Richmond, VA
Massey 2860M Cab, Massey 1E.35, Gravely Pro-Turn 560, 1989 Ford D47 Dump Truck
Good morning all. Two questions fro all the builders on here:
1. Is it a good idea to put the sheathing on frst and run it to the top plate. Then cut the birds mouth on the rafter to go over it and the 2 by 4? Hope I said that correctly!!! LOL
2. Have you used the Zip System? Is it a good way to go. I am building a 12 by 20 shed that I am insulating and putting electric in for my wife and kids to use.
Thanks
   / Sheathing and Birds Mouth on Rafter #2
Thanks
hmmm, the birds mouth is on the bottom of the rafter. The heel and seat cut are commonly called the bird’s mouth.
Correct. Is it ok to run the sheathing first up to the top plate and put the birds moputh over the sheating and the top plate?
   / Sheathing and Birds Mouth on Rafter #5
Also, I never said the birds mouth was not on the bottom of the rafter?
Sorry, brain fart this morning.....The wall sheathing is usually put on after
   / Sheathing and Birds Mouth on Rafter #6
Depends on your construction method. I like to square the walls and put on some or all of the sheathing while the wall is flat, then stand it up and put on the roof. A lot quicker but you need to be very careful in squaring everything because you can't adjust it later.
   / Sheathing and Birds Mouth on Rafter #7
I'm guessing you asked about sheating first because you want to avoid notching your sheating around the rafter tails.
One consideration is you don't want to notch so deeply into the rafter that the tail becomes weak.
Another consideration is whether you intend to add a soffit that would cover this area anyway.
Whatever you do, the entire job will be 1000% easier if your foundation is plumb and square. If the foundation is off, that will make the entire framing job much more of a pain. You need to be sure the foundation and the walls go up plumb and square if you intend to sheat first and then you don't want to notch too deeply into your rafters.
   / Sheathing and Birds Mouth on Rafter #8
I like putting sheeting on up to the top plate first, and then make the birds mouth to fit over the sheeting.
To be honest, I have never seen it done another way.
I got it. I talked with a builder frined of mine. I am square within 1/16 to 1/8 inch. Everything is plumb and level from pier blocks up. Only checked one thousand times. LOL Thanks for the replies.
   / Sheathing and Birds Mouth on Rafter #10
I hope you have a good helper to help you set those rafters whatever you do.
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
WOODS DS8.30 LOT NUMBER 52 (A53084)
WOODS DS8.30 LOT...
2019 Caterpillar 966M Articulated Wheel Loader (A51691)
2019 Caterpillar...
UNUSED AGT AIR COMPRESSOR W/ 420CC MOTOR (A51248)
UNUSED AGT AIR...
1998 Talbert TDW-35S-HRG-1-T1 Detach, GVWR 84,300 (A52384)
1998 Talbert...
UNUSED HURRICANE D6028 - 5' JOB BOX (A51248)
UNUSED HURRICANE...
