Snow Shearpin Help
   / Shearpin Help #1
dieseler
New York State
I have a GC2600 with a newmassey snow blower. Lost the shearpin for the fan on the last storm (Gold shear pin).
I can line up the holes with a screw driver, I positioner the augers noted in the manual but I cannot get the shear pin to go through the hole.
Any tricks, experience, ideas?
TIA
   / Shearpin Help #2
There's generally some lash --in and out play-- in those things; perhaps the fan needs to be pulled out or pushed in just a bit?
A tapered drift punch works very well to both line up the holes and make sure they're completely clear (no metal chunks). It can also be tapped in just a bit to smooth out a burr if there is one.
   / Shearpin Help #3
When you break or tear a shear pin out sometimes it comes out alittle rough and may have left a burr on the hole/shaft.
Craig Clayton
   / Shearpin Help #4
Drive a nail or drift pin of some sort through the bolt hole. You probably had the bolt leave a piece in the hole. Happens to me often enough I carry a nail with tools to replace bolt. If in doubt the holes are aligned, just insert the point slightly and slowly rotate the fan. You should feel when the holes line up.
   / Shearpin Help
(1) right angle drill and a 5/16" bit later..problem solved.
   / Shearpin Help #7
I assume there was a piece lodged in the hole?
   / Shearpin Help #8
I've had luck using an allen wrench and pliers to tap the shear pin out.
   / Shearpin Help
So hard to tell exactly what was wrong.
I could fit the 1/4" drift through with no problem. When I tried to get the 5/16" bolt through it would not fit and after "tapping" it through the threads on it were gone.
Soran the bit through some metal came out and now all is good.
   / Shearpin Help #10
dieseler, happy it's fixed. I am considering taking the cab and blower off and storing. Not quite, but almost time to start tilling the garden.
One thing about making that blower etc investment. It works!!!! Snow goes elsewhere (Y'ano like NY) after pulling the pin on that grenade. ;-)
SET OF (2) DELTA DUMP TRAILER SWINGING DOORS (A51244)
SET OF (2) DELTA...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50324)
2018 Toro Grounds...
2020 KUBOTA RTV...
2008 Ford F-350 4x4 Pickup Truck (A50323)
2008 Ford F-350...
CATALOG IS A GUIDE ONLY!! (A50774)
CATALOG IS A GUIDE...
UNUSED KIVEL SKID STEER QUICK ATTACH PALLET FORKS (A51244)
UNUSED KIVEL SKID...
