Shear pin
/ Shear pin #1
coolbrze
VA
Kubota MX5800
Broke a shear pin on my Razorback Bushhog yest. w/ my Kubota. It has 3 lines on it like a Grade 5 bold does. Is it as simple as going to my Home Depot or Lowes and buying a similar bolt, or do I need a special bolt from the dealer that will break under certain pressure? Thx.
/ Shear pin #2
Most likely that's all it is. My Woods snow blower uses a grade 5 bolt that I pick up at any hardware store (but came with a grade 8 from the factory, a whole other story!). Check the manual, mine says any grade 5, 1/4 inch by 1 inch will do. I just keep a few in the tool box on the tractor.
/ Shear pin
Ok thanks. One more question. Is this bolt threaded in or do I just slide it in, put the nut on, and tightern it down? Reason I'm asking is b/c I tried taking it off several months ago, and the bolt just spun and spun. Maybe the threads are shot?
/ Shear pin #4
The holes on the driveline should be clearance (not threaded). Buy a handful of the right bolts and self-locking nuts to match. You don't want much clamp load and with plain nuts they'll vibrate right off /forums/images/graemlins/smile.gif
/ Shear pin #5
The replacement bolt is common hardware. Check your mower manual for the correct bolt. Sometimes the assembler at the dealer just sticks a bolt in! I use the normal nut and sometimes add a lock washer. Never a problem. Lightly tighten the nut onto the bolt.
Leo
/ Shear pin #6
If you buy a bolt that's long enough so it sticks out of the nut by a few threads, you don't need any locking harware. Just use channel-lock (or vise-grip) pliers to slightly flatten the threads that you protrude from the nut. The nut will never come off by itself and you can still remove it if you ever want to. This just saves having to fool with any locking hardware. I've been doing this for over eight years and I've never had a nut back off and come off the bolt. /forums/images/graemlins/cool.gif
2016 INTERNATIONAL 4300  4X2 24FT BOX TRUCK (A59908)
2016 INTERNATIONAL...
2024 JOHN DEERE 325G SKID STEER (A62129)
2024 JOHN DEERE...
2011 SOUTHWEST  GOOSENECK (A58214)
2011 SOUTHWEST...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 RoGator 1100C (A61307)
2018 RoGator 1100C...
