Rotary Cutter Shear pin?
/ Shear pin? #1
TVZ
MF 1726E
I seem to have sheared a pin that holds the PTO shaft onto the gear box shaft on my old KingKutter rotary cutter (L-48-40-P-Y). It is about ス" diameter. The part that is left is 1 シ"" long (the diameter of the shaft coming out of the gear box). Apparently the ends sheared off and are gone. Questions:
--Is that a "shear pin"? Is that what I would ask for?
--Is that a standard generic item that I could get somewhere locally or through Amazon or something? Or do I need to get it from KingKutter?
--Can I put a bolt in there for now and keep working?
Thanks...
/ Shear pin? #2
not knowing where it came from you could have one or maybe not! lol Considering we think it is they often use grade five bolts.
/ Shear pin? #4
TVZ see if thats what your talking about ? King Kutter Grade 2 Shear Bolts 5:)1
They are number 2 . Rural King /TSC / etc replace with correct bolt if thats what you need . ???
Respond back too us either way .....
/ Shear pin? #5
Most implements start out in life with a 1/4 inch diameter grade 2 bolt for a shear bolt (pin) if not splined shaft... Over time and many failures they seem to grow to grade 5 or grade 8 and increase in diameter to 3/8 inch or larger....
images
Dale
/ Shear pin? #6
Dad and I went to two stores (won't name them, but are tractor supply stores) and neither knew what a shear pin was. Finally realized that we just needed to ask for the grade of bolt that we needed.
/ Shear pin?
Yes, Bullbreaker, that looks like what I need. I am out in the sticks and will have to order them. Is it ok to use a normal 1/2" bolt for the meanwhile?
/ Shear pin? #8
I wouldnt the damage could be WORSE ! Amazon should have that also if you got prime you can get it quick !
/ Shear pin? #9
I had a cutter that liked to shear bolts, geeeeeze I learned to hate that thing!
I got sick of dealing with wrenching nuts on the bolts I put in, so I extra bought bolts, put them on a anvil and hammered flats on both sides of the bolts, it only takes a few blows. Then to replace them, you just drive them in as they go in tight! NO nut needed...
When that cutter got replaced, that's when I switched to Woods rotary cutters and drive line slip clutches!
PROBLEM SOLVED!!
SR
/ Shear pin?
Are shear bolts (#2 bolts) softer than regular bolts?
/ Shear pin? #11
Depends on what you mean by 'regular'.
The plainest unmarked-head cheap grade 2, not grade 5 with the '3-spoke' head marking, unless you're hard on 'em & want to push the limit of 'ok'. :) (its done a lot within reason)
They're sized/intended to give way comfortably shy of breaking something else between PTO and turf. I have 'em & break 'em on & only when using the slasher, usually if too high rpm, too low to ground, too quickly releasing the clutch, or a combination of them .. clumsy operating. ("Hello it's me, .." ;))
But grade 2s are cheap by the pound at TSC. I use jam nuts when I install vs tighten against a hub.
/ Shear pin? #12
Hate to steer you wrong but most use grade 5 or 8 for shear bolts. Grade 2 are very ductile material and tend to smear when they break. Grade 5s and harder fracture clean and are easy to remove. They also tend to specify shear bolts of a size so the solid portion is in the shear area meaning no threads at the shear point. Gives a more consistent value at fracture.
/ Shear pin? #13
Most most common bolts in use are grade 2, grade 5 and grade 8... Other grades exist but usually for "special" applications...
SAE Grade 2 - 74,000 psi, low carbon steel (no spokes on head)...
SAE Grade 5 - 120,000 psi, medium carbon heat treated steel (3 spokes on head)..
SAE Grade 8 - 150,000 psi, medium carbon alloy steel (6 spokes on head) ...
Dale
/ Shear pin? #14
I actually bought a package of King Cutter shear bolts/lock washers/nuts. They're grade 2. Probably cost a dollar or two extra but it was easier than buying individual parts and they were packaged nicely.
Kevin
/ Shear pin? #15
I agree with this as well.
Soft will elongate and damage the holes while grade 5 will shear nice and clean.
IMHO 5 is nice and should still protect the equipment all while shearing clean.
It was mentioned that often the holes grow bigger over time and that was probably due to damaged aligning holes from soft bolts.
My experience is mainly from snow blowers. (and most use grade 5)
10000LBS Two Post Auto Lift (A64194)
10000LBS Two Post...
2018 CATERPILLAR 303ECR EXCAVATOR (A65053)
2018 CATERPILLAR...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A64556)
2022 Mac Trailers...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2016 Jeep Patriot Sport SUV. (A64557)
2016 Jeep Patriot...
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
