Shear Pin Torque?
   / Shear Pin Torque? #1
ammodram
Western Pennsylvania
Kubota L245DT
Dumb question:
How tightly should the drive shaft shear bolt / nut on a rotary cutter be tightened? Is there an optimal degree of torque that makes it break most cleanly? Should it be just snug, or really cranked?
Thanks
Matt
   / Shear Pin Torque? #2
Not dumb at all. I recommend no torque whatsoever. Use a NyLok nut, and perhaps a flat washer. Just tighten the NyLok enough so the bolt doesn't flop around loose. What makes a shear pin work is a shock load that exceeds its load bearing capacity. Torquing one down risks altering that capacity by adding the strength of the materials it's compressing.
//greg//
   / Shear Pin Torque?
The pin that came on my mower has a flat washer and a regular metal lock washer. I just snugged it up, but didn't tighten it too much.
Thanks,
Matt
   / Shear Pin Torque? #5
If it is loose, the holes will tend to wallow out. You want it tight enough to keep the2 parts from moving back and forth. But not so tight as to keep them from ever moving! Probably 20-30 ft-lb. I just use my calibrated wrench hand....
jb
   / Shear Pin Torque? #6
Ammo:
Do you have a manual for the rotary cutter? If so, a torque value should be in the manual. Is the cutter manual available online from the manufacturer? My Bush Hog RZ60 (5' light duty cutter) recommends 49 lb/ft of torque for the 1/2-13 x 3" Grade 2 shear bolt.
   / Shear Pin Torque?
It's a King Kutter and I can't find anything about how much to tighten the pin in the manual. It's actually the same manual that Soundguy posted a while back in reference to sizing PTO shafts.
I'll just snug it up a little, but not monkey it.
-Matt
   / Shear Pin Torque? #8
Well, certainly don't put a grade 5 in one. I spent the whole day cutting, welding and bending a brush hog back in to shape that my buddy tore up. The price is right, though!
I'll post a few pics tonight or tomorrow.....almost got it back together......gotta make a gasket for the gear box......
2012 MACK PINNACLE CH613 FLAT TOP DAY CAB ROAD TRA (A51243)
2012 MACK PINNACLE...
2019 Tico Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, Cab w AC (A52128)
2019 Tico Yard...
2005 KOMATSU PC400LC-7L EXCAVATOR (A51242)
2005 KOMATSU...
2018 KUBOTA MS-091 TRACTOR (A51243)
2018 KUBOTA MS-091...
2022 ESTATE MOWER 6' FINISHING MOWER (A51243)
2022 ESTATE MOWER...
TRAILER AXLE (A51244)
