Shear pin / bolt for light duty rotary cutter
   / Shear pin / bolt for light duty rotary cutter #1
Bill Hunt 40
Shear pin/bolt for 5’ rotary cutter diameter and length
   / Shear pin / bolt for light duty rotary cutter #2
Lots of other variables. Probably go with what came with your cutter.
   / Shear pin / bolt for light duty rotary cutter #3
Any Grade 2 (low strength) bolt and nut from your local hardware store.
Very poor tractor identification.
   / Shear pin / bolt for light duty rotary cutter #4
Many of the rotary cutters I've seen at least have a retaining ring on the gearbox shaft to prevent the PTO shaft from sliding off and flailing around when the shear pin breaks. It's important to have that retaining ring in place when you replace the shear bolt.
   / Shear pin / bolt for light duty rotary cutter #5
I've been using grade 2, 7/16" bolts and double-nutted for my old Howse cutter for over 24 years. Probably 9 out of 10 times the busted bolt (both halves) land on the deck of the cutter and I'm able to salvage the 2 nuts for another bolt. The PTO shaft has never come off the gearbox, if anything it extends out longer until it stops against gearbox. Of course some gearboxes may have different input shafts that could cause the shaft to fly off, my Howse is a very old one with a mighty hefty gearbox on it for a 6' cutter.
   / Shear pin / bolt for light duty rotary cutter #6
Yes, spent two hours yesterday taking out a broken shear pin. The head was stamped grade 8. Not the right stuff for shear pins
   / Shear pin / bolt for light duty rotary cutter #7
1/2" x 3 1/2" Grade 2 is what we use in our cutters
LMC LOT NUMBER 143 (A53084)
LMC LOT NUMBER 143...
2025 New/Unused Wolverine 72in Skid Steer Hydraulic Rotary Tiller (A51573)
2025 New/Unused...
2012 JOHN DEERE 410K BACKHOE (A51246)
2012 JOHN DEERE...
2005 INTERNATIONAL 4300 24FT BOX TRUCK WITH TRANSLUCENT ROOF (A52577)
2005 INTERNATIONAL...
