Shear Madness
   / Shear Madness #1
huckflynn
NY
Kubota BX2660
I hadn't broken a shear pin on my BX2750 in over 2 years. Over the last 2 days I've broken 3 including (for the first time in 9 years) the fan's shear pin. In breaking the fan's shear pin I was surprised at how much damage was inflicted before the shear pin gave way. One of the fan blades was bent out and caught the lip on the housing bending that in. I managed to bend things back into shape and get things turning smoothly again. I didn't have a shear pin for the fan so I stopped by the dealer and picked up a couple -- 72 cents apiece. I didn't have any cash with me and couldn't see putting a charge through for 1.44 so I looked around for something else to buy and found a nice Kubota BX hat. Got back to the house and fumbled with tightening the shear pin on the fan. Got everything together and headed down to clear the drifting snow at the bottom of my driveway. Must have been 2 minutes into it when bam -- rock -- 3rd shear pin in 2 days. This was just the left side auger so I finished the job with the right side of the blower and put the tractor away.
I'll deal with that other shear pin tomorrow (I have a good supply of the auger shear pins.)
   / Shear Madness #2
Bad luck? Either that or these new fangled shear pins are not as good as the old ones. Maybe the paint on the original ones makes em last longer :confused:
   / Shear Madness #3
Huh, just be glad you're breaking shear bolts instead of gearboxes like me :)
   / Shear Madness #4
I hadn't broke any in probably 10 years on my blower until this year and three in two days. I would say buying only 2 is being an optimist. ;)
2019 FREIGHTLINER WATER TRUCK (A58214)
2019 FREIGHTLINER...
2018 HINO 268 24FT NON CDL REEFER BOX TRUCK (A59575)
2018 HINO 268 24FT...
MARATHON 76KW GENERATOR (A58214)
MARATHON 76KW...
WBrock Meyer 2000S 70'x12' 2000 BPH Grain Dryer W/Legs&Mill Discharge Sylo,Controller is included (A57148)
WBrock Meyer 2000S...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
New/Unused CFG Industrial MX15RX Mini Excavator (A57453)
New/Unused CFG...
