Snow Shear bolts in 47" front snowblower
   / Shear bolts in 47" front snowblower #1
chipsndust
Platinum Member
central NY and Adirondacks
JD 1025R, Curtis cab
I have been using grade 5 bolts for shear bolts in the augers and impeller (1 X 1/4-20 , with nylon insert nuts). They seem to be breaking pretty easy.
I am tempted to try grade 8 bolts of the same size, sure seems like a grade 8 1/4" bolt would break before anything else in the drive train?
I stopped buying the shear bolts from the dealer at about $4.00 each.
Anyone using grade 8 bolts for shear bolts?
   / Shear bolts in 47" front snowblower #2
I have the same blower, and would not upgrade to grade 8 bolts. They original shear bolts are made to shear, if the blower gets jammed, before you damage a gearbox. I,m sure you can probably get cheaper bolts at TSC, or a hardware store.
It,s much cheaper to replace a few shear bolts a year, than a gear box, or worse.
   / Shear bolts in 47" front snowblower #3
I would stay with the grade 5 bolt, but there is no reason to pay that much for them. You should be able to buy them by the pound at any box store for a whole lot less. A trick I learned is when replacing a shear bolt, make sure it is clean and dry, then use some blue thread lock-tight. I think the nylon lock nuts work loose and things start moving a bit and that is what breaks the bolt. Or try using the more expensive conical lock nut.
   / Shear bolts in 47" front snowblower #4
Bigtiller is right! I use to break shear bolts like crazy the first year I had it, until I realize that the bolt were coming loose. I did not use lock-tight, but I did put them tighter. Fix my problem. Now I brake one maybe two per winter. Didn't brake any this winter, yet. :eek:
Thanks, guys.
I have been buying the grade 5 bolts at TSC.
I have noticed that they tend to loosen up. I'll keep a closer eye on the tightness and maybe try a different type of locknut.
   / Shear bolts in 47" front snowblower #6
Agree with the others ,the nuts work loose and that is when the bolts seem to break . I don't like using the nylon because they seem to work loose .
Last few times I tighten the bolt and nut and then put another nut on and tighten it, I went and was able to do the 9 driveways 3 times before breaking a bolt..
   / Shear bolts in 47" front snowblower #7
I have a rear blower but was going through many shear bolts, (TSC 1/4"x20 plated Gr 5), mainly on the fan side but sometimes on auger, even on flat, smooth driveways. I found that when I "opened" up the chute lid to blow farther, I broke much less of the fan bolts then when I had the chute "down", which reduced flow and trajectory. The auger seems to be able to shove more snow than the fan could eject. When wide open, rarely break a bolt and then mainly the auger after hitting something (like my dog's XL KONG toy with Nylon rope).
2025 JMR 72in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 JMR 72in Dual...
2022 Brush Wolf 4800X Severe - Duty Excavator / Backhoe Brush Cutter (A55314)
2022 Brush Wolf...
2014 Jeep Compass 4x4 SUV (A55853)
2014 Jeep Compass...
2013 Ford F-250 Ext. Cab Pickup Truck (A51692)
2013 Ford F-250...
2015 Ford F-150 Ext. Cab Pickup Truck (A53422)
2015 Ford F-150...
2013 Club Car Carryall 252 Electric Utility Cart (A51694)
2013 Club Car...
