Snow Shear bolts in 47" front snowblower
   / Shear bolts in 47" front snowblower #1
chipsndust
Platinum Member
central NY and Adirondacks
JD 1025R, Curtis cab
I have been using grade 5 bolts for shear bolts in the augers and impeller (1 X 1/4-20 , with nylon insert nuts). They seem to be breaking pretty easy.
I am tempted to try grade 8 bolts of the same size, sure seems like a grade 8 1/4" bolt would break before anything else in the drive train?
I stopped buying the shear bolts from the dealer at about $4.00 each.
Anyone using grade 8 bolts for shear bolts?
   / Shear bolts in 47" front snowblower #2
I have the same blower, and would not upgrade to grade 8 bolts. They original shear bolts are made to shear, if the blower gets jammed, before you damage a gearbox. I,m sure you can probably get cheaper bolts at TSC, or a hardware store.
It,s much cheaper to replace a few shear bolts a year, than a gear box, or worse.
   / Shear bolts in 47" front snowblower #3
I would stay with the grade 5 bolt, but there is no reason to pay that much for them. You should be able to buy them by the pound at any box store for a whole lot less. A trick I learned is when replacing a shear bolt, make sure it is clean and dry, then use some blue thread lock-tight. I think the nylon lock nuts work loose and things start moving a bit and that is what breaks the bolt. Or try using the more expensive conical lock nut.
   / Shear bolts in 47" front snowblower #4
Bigtiller is right! I use to break shear bolts like crazy the first year I had it, until I realize that the bolt were coming loose. I did not use lock-tight, but I did put them tighter. Fix my problem. Now I brake one maybe two per winter. Didn't brake any this winter, yet. :eek:
Thanks, guys.
I have been buying the grade 5 bolts at TSC.
I have noticed that they tend to loosen up. I'll keep a closer eye on the tightness and maybe try a different type of locknut.
   / Shear bolts in 47" front snowblower #6
Agree with the others ,the nuts work loose and that is when the bolts seem to break . I don't like using the nylon because they seem to work loose .
Last few times I tighten the bolt and nut and then put another nut on and tighten it, I went and was able to do the 9 driveways 3 times before breaking a bolt..
   / Shear bolts in 47" front snowblower #7
I have a rear blower but was going through many shear bolts, (TSC 1/4"x20 plated Gr 5), mainly on the fan side but sometimes on auger, even on flat, smooth driveways. I found that when I "opened" up the chute lid to blow farther, I broke much less of the fan bolts then when I had the chute "down", which reduced flow and trajectory. The auger seems to be able to shove more snow than the fan could eject. When wide open, rarely break a bolt and then mainly the auger after hitting something (like my dog's XL KONG toy with Nylon rope).
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
Crash Mobile S/A Trailer (A50324)
Crash Mobile S/A...
2015 Polaris Sportsman 570 SP ATV (A50514)
2015 Polaris...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51406)
KNOW BEFORE YOU...
Bush Hog Mod. 300 - 14 3 pt Blade (A50514)
Bush Hog Mod. 300...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
