Shear bolt or pin on FM
   / Shear bolt or pin on FM #1
jebster54
Pensacola, Florida
JD 3032E
I have a 5' FM that has a blade that is not turning with the other two, but I can spin it freely with my hand. I bought it used and just noticed that the blade did not cut on one side! Where do I get the shear bolt and is that the fix?
   / Shear bolt or pin on FM #2
Depends on the mower. Is this a rear finishing mower or a mid-mount mower? Most mowers these days don't have shear pins on the blade. Do you know the brand of mower it is?
It is a rear FM and is made by Costal Machinery. Belt driven, 3 blades with rear chains where the grass exits.
If they don't make shear bolts what would let it spin freely?
   / Shear bolt or pin on FM #4
I think Coastal Machinery is the dealer and not the manufacturer. How are your blades mounted to the spindle? Is there just one bolt through the center of the blade?
Thanks, you're right, not sure what kind it is but their is only one bolt holding it to the spindle.
   / Shear bolt or pin on FM #6
Most blades these days don't have a shear pin in them. Your blade mounting bolt is either loose or stripped.
This FM looks like an older model. So if it is stripped will I need to replace the spindle and bolt to fix it? It appears to be on tightly.
   / Shear bolt or pin on FM #8
Try to tighten it. The bolt may have been loose for a while and the bolt has frozen with the blade not seated. I would not try to repair a spindle if it was bad. They are not all that expensive compared to the grief a bad spindle can cause during the mowing season.
   / Shear bolt or pin on FM #9
It is possible that you have a broken belt going from the center blade to the outside blade. Some mowers use 2 belts to drive all the blades and some only use 1 very long belt that goes around all the pulleys.
   / Shear bolt or pin on FM #10
Just about all RFM mowers made now have a single Kevlar belt.
2018 JLG G5-18A (A50123)
2018 JLG G5-18A...
2019 KUBOTA KX057-4 EXCAVATOR (A51246)
2019 KUBOTA...
2014 International DuraStar 4300 4x4 Terex BT3063 63FT 15 Ton Crane Truck (A51692)
2014 International...
40ft Sea Container (A52384)
40ft Sea Container...
40' CONTAINER (A51248)
UNUSED X-STAR 750 GALLON FUEL TANK (A51247)
UNUSED X-STAR 750...
