Rotary Cutter Shear Bolt and Slip Clutch
   / Shear Bolt and Slip Clutch
Well I checked and there are no splines on the shaft. The shaft also has a circlip at the end that would hold the yoke on if the bolt would shear. I guess I have both and I am in luck. Thanks for the help all.
Yes you are right. They do look very similar. I have to agree.
I will have to look closely at mine to see if there are casting marks.
   / Shear Bolt and Slip Clutch #25
I have a similar setup on an old IH 500 brush hog. I run both the clutch and shear bolt. To date I haven't had the bolt break, but I do mow some pretty heavy sugar maples with this rig. one question, why is the slip clutch attached at the PTO spline of the tractor? shouldn't it be located at the Mower gear Box? At least that is how my set up is.
thanks, Phil C.
   / Shear Bolt and Slip Clutch #26
Absolutely. Each slip clutch should be adjusted to a specific implement, thus maximizing both safety and efficiency. Some simply don't realize this, and others think they're saving money by using one common (tractor mounted) slip clutch for all their PTO-driven equipment.
//greg//
thanks, Phil C.
It is attached to the gearbox of the brushog. Interesting that we have both.
   / Shear Bolt and Slip Clutch #28
As I stated in post # 6 double protection is a good thing, unless you believe posts 5 & 7 :confused2::confused2:. :cool: MikeD74t
   / Shear Bolt and Slip Clutch #29
Wow, after reading what you found, I went back and re-looked at that first pic, I totally missed the nut/stud sticking out the other side. Duh.
It definitely has a shear pin. I took the it out. No splines or no keyway. I guess I am doubly protected.
2014 Chevrolet Express 3500 Cargo Van (A55852)
2014 Chevrolet...
2013 Ford Edge (A54815)
2013 Ford Edge...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A55315)
2023 Kubota U48-5...
2015 INTERNATIONAL FLATBED (A58214)
2015 INTERNATIONAL...
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
2023 PJ Dump Trailer (A55973)
2023 PJ Dump...
