She finally broke
/ She finally broke #1
escavader
western maine
bx-23 ,
1900 hard hours my bs 23 finally broke .i have been so hard on this tractor over last 10 plus years everyone including myself are just amazed of its toughness .ive always serviced it by the book but I've asked way more than what it's made for.
So hauling gravel down a road low gear driving slow and all of a sudden a wicked grinding noise .i stopped immediately backed up and I saw a streak of oil .shut her down got off and oils pouring out of the tranny!
Jacked her up when you turn one tire the other don't rotate the opposite(or at all) way and spins way to easy started it up after checking if any oil in it and no leaks???? But when you try to move her it sometimes grinds
My initial guess broke ring gear,or axle,or differential lock ?
Towed home in neutral, drove it on trailer and unloaded under her own power at dealer
I gotta fix it but wifey says it don't owe us anything and I should get a bigger tractor.
Geez I hate to give up my cab my hoe my bush hog is only 4 ft my blowers only 54 what a decision I have sat on the b 3350 tonight I like the size same width as my blower(guess I could make wings for it) the L felt too big for what I do I think holy cow by the time I buy the 3350 buy a hoe I'm in it for a lot of dough! Thinking keep 23 buy the 3350 with farmi winch call it good gosh my heads going mile a minute
Keep ya all posted what they find
/ She finally broke #3
Sorry to hear of the problem. Tough call since you have a lot of equipment for the BX that would be undersized for a larger tractor. That seems to point to either a repair or a replacement that's close to the same size.
/ She finally broke #4
I say you just got a warning sign what maybe laying ahead.:eek:
Best towards your quest.
/ She finally broke
Looked at the b3350 I think .i liked but reading on here lots of issues with smog crap sat on the Los too wow they are big but nice
/ She finally broke #6
Tractors use to excite me. I would stop at the dealer all the time to see what's new. Now with the tier4 junk, I drive right by. The EPA killed the diesel engine. Trucks are worse, you have to add cow pee pee.
/ She finally broke #7
I love my little BX23. But maybe you should look at a new BX25 or perhaps another gently used BX23. I see them come up for sale from time to time.
/ She finally broke #9
I'm afraid to find out how much to fix???? I'm sitting down, go ahead and tell me..
/ She finally broke #11
Get an estimate of repairs before you do anything. Hopefully it won't be as bad as you think.
Many, many years ago I started with a 12 HP riding lawnmower. When that engine gave up, I put an 18 HP engine on it. It still took 8 - 9 hours to mow my place. Then I found an old red Cub that ran real good, and it had a Woods 5ft belly mower. The neighbors laughed at me! Mowing time went down to 4.5 hours. Years later I bought a brand new New Holland TC35 and a Bush Hog RDTH 60 finish mower. Mowing time is 1 3/4 hours now! I had to buy more implements to fill my spare time!
What I'm saying is, you won't go wrong with a bigger modern tractor and bigger implements.
Good fortune!
Scott
/ She finally broke #12
Good fortune!
Scott
Get a dedicated zero turn or front mounted mower and you'll be down to 1.0hrs! :cool2::drink:
/ She finally broke #13
Hi Luke,
That may be true but I can't see not having control of the front wheels. Besides, I cannot afford to have two expensive machines and dont know where to hook up the grader blade, the box blade, the middle buster, the bush hog, the post hole digger, the dirt scoop........etc, ad nauseum. My neighbor is so proud of his ztr that he now has a note on a new tractor that he uses once in a blue moon, borrowing my implements!
/ She finally broke
So wife wants to buy me a l3300'with hoe for 25000 what do u all think of that setup?
/ She finally broke
I'd have to get new blower bush hog box blade for new one ohh brother
/ She finally broke
I guess it must be a b wife told me 3300 gave me no letter dealer said bigger tires then 3350 I was looking it and no smog crap
/ She finally broke
/ She finally broke #20
Run with it and don't look back! My wife would rather but me a leash!
20ft. 2-Door Shipping Container (A61572)
20ft. 2-Door...
2016 Ford Escape SUV (A61569)
2016 Ford Escape...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 FREIGHTLINER...
2018 Trail King Lowboy (A63689)
2018 Trail King...
2000 GMC W3500 Cab and Chassis Truck (A59230)
2000 GMC W3500 Cab...
Kubota V3600-E3-EG60 Diesel Engine - 3.6L - Tier 4i - Irrigation Pump Takeout (A63689)
Kubota...
