jgbanshee
- Joined
- Sep 16, 2004
- Messages
- 316
- Location
- PA
- Tractor
- JD 310SE, 4300, 5300, 5210, 450 Crawler, CAT D3B, Ford 2N, 5000, 4000su, 3610, 345C, 340B, 1100
I have an older Shaver HD8 post driver hooked up to a Ford 4000 that is not working. The cylinder does not want to extend on its own. If I push up helping it a bit and pull single spool valve lever back the cylinder will lift slightly, approx. a couple inches to a foot. After that when I push the single spool valve lever the other way the cylinder will not retract at all. The springs are in very good condition. Hydraulics are plumbed from tractor remote and dumps back into rear axle for return. The lines are hooked up properly. I cracked the line at the cylinder and oil squirted out when pulling lever. The post driver guides/frame are oiled generously. I took the top nut off the cylinder and removed cylinder from the driver, pulled the control lever and cylinder extended with no problem. What is left to check on this to get it working properly?
