Shattered Dreams & Bent Hopes!!!
   / Shattered Dreams & Bent Hopes!!! #21
</font><font color="blue" class="small">( If the trucks that we buy were to fall a part and the windshields were to explode when the doors were closed how long would they stay in business? )</font>
In fact there are spontaneous failures with safety glass all the time. It may not have happened to you but I've had several failures with no attributable reason. On the flip I've also had glass with what should be terminal chips or cracks hold fast. I've always considered safety glass a mercurial substance it definitely has it's own mind when it comes to when and how it will fail. The only constant I've found is that when it finally does fail it does so in the safest manner possible, as your pictures attest.
As to your other failure, it's a good lessen for all of us. It would seem that ten minutes and a couple of wrenches will save a ton of heartbreak. It’s a lessen I’ve learned the hard way in the past and one that occasionally needs refreshing. (At least with me. /forums/images/graemlins/blush.gif ) Thanks for posting; it defiantly inspired me to give my machine its due diligence. By the way Rick is my dealer as well and I know what you mean about him going out of his way…….. I had an issue with a PTO shaft that was cut too short. He fixed me up in no time and with a smile to boot. /forums/images/graemlins/grin.gif
Regards, Jamie
   / Shattered Dreams & Bent Hopes!!! #22
</font><font color="blue" class="small">( Loc: Alton, New Hampshire )</font>
i have nothing to add but say
Hello fellow Altonian!
I live in Alton Hampshire UK /forums/images/graemlins/grin.gif strange huh?
   / Shattered Dreams & Bent Hopes!!! #23
</font><font color="blue" class="small">( I live in Alton Hampshire UK strange huh? )</font>
Yeah, you're a little strange, but we like you okay! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / Shattered Dreams & Bent Hopes!!! #24
The washers/bolts just serve as something to hold the pin in and the o ring to hold the grease in. If the bolt falls out the pin vibrates over and bang. It really is hard to fault any one thing. Too many if's. Maybe locktite or a lock washer would help.
At the same time just as a example I almost had the same thing happen on a CK30 loader. BUT they are held on by lynch pins. The pin unfolded and popped out working in brush. Could have easily looked like your loader.
Believe me I understand your ire, but as others have said Rick will fix you up. Dealers don't come much better than Rick.
I think we will begin "lock-tite"-ing our little bolts from now on, but then you risk a customer snapping a bolt trying to get it out to take off a bucket or something......
Catch-22
Good Luck
KO
   / Shattered Dreams & Bent Hopes!!! #25
Unfortunately, all of us don't have great dealers that will go the extra mile. I've been struggling with my KL1595 loader on the DK55 for awhile now. No help from the dealer and certainly no help from KMW or Kioti. There is supposed to be a fix coming, but I haven't been contacted by Kioti to let me know and they quit responding to my email after the first courtesy response.
I'm afraid that I'll be put off until my warranty is expired and then will be stuck with the junk. I've also had many other problems in my first 60 hours of use. I'm sorry to say that I am starting to hate my tractor. I'm not sure what I'm going to do with this tractor if I don't get the loader fixed, but continuing to pay for it is not one of them.....
   / Shattered Dreams & Bent Hopes!!! #26
Wow Kioti is really taking a hit here this spring. I had my loader problem resolved last spring but am patiently waiting for a smokey start up problem to be resolved. Anybody know about Lemon Laws and tractors or consumer protection?
   / Shattered Dreams & Bent Hopes!!! #27
<font color="blue"> smokey start up problem to be resolved. </font>
I think that is called being a diesel. /forums/images/graemlins/smirk.gif
My DK65 will shoot a little out on start up, and as soon as all the warranty is out, it'll shoot more!! /forums/images/graemlins/grin.gif
My Suburban and VW Golf , (both diesels) will blow smoke on start up.
RedDog
   / Shattered Dreams & Bent Hopes!!! #28
/forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif
Did you turn up the V-dub ??
Been thru Nelsonburg lately??? /forums/images/graemlins/grin.gif
KO
2022 Vermeer 573 (A55973)
2022 Vermeer 573...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
1990 MACK RD688S (A58214)
1990 MACK RD688S...
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
2017 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4x4 - Versalift SST40 Boom (A55302)
2017 Ford F550...
2006 TerraGator 8104 (A56436)
2006 TerraGator...
