Sharpening the blades on a MX6
   / Sharpening the blades on a MX6 #2
I leave them on and use a angle grinder to sharpen them. If you take them off you will need a torque multiplier to re-torque to something like six hundred foot pounds of torque. If you have a multiplier you might try it, but if you lift the unit and put jack stands under it, it is safe, easy and quick.
   / Sharpening the blades on a MX6 #3
I didn't have an MX6, but I took the blades off my Bush Hog and my Howse. A neighbor sharpened his bigger and older Howse without taking them off because he couldn't get them off.:D And other TBN members have done it both ways, also.
   / Sharpening the blades on a MX6 #4
I have 3 rotary cutters and sharpen them all with an angle grinder. Years ago I wrestled with removing the blades but no more. I can do it in 5 minutes by lifting deck with tractor 3ph to highest point, blocking it up with a 2" x 6" for safety, and sharpen blades with angle grinder. Some folks run the tractor and cutter up on a trailer to get it raised high enough.
   / Sharpening the blades on a MX6 #5
It's a lot easier to sharpen the blades on the cutter than taking them off and putting them back on. Like everybody else has said, just be safe, wear eye protection and make sure that the cutter can't come down on top of you.
   / Sharpening the blades on a MX6 #6
Any suggestions for sharpening the two sets of blades on a Semi-mount MX8?
I can raise it up about 10-12 inches off the ground, but that's it. Not excited about crawling under that beast with a grinder.
   / Sharpening the blades on a MX6 #7
Do you have a FEL? If so, lift one side up and sharpen the blades with an angle grinder. I'd use a chain to hoist and hold for safety sake. Some of those cutters are very heavy but you have to be careful getting under/near all of them being sure they are supported while you work.
Thanks to everyone for their advice. I backed the bush hog over a ditch, raised as high as it would go and blocked it up. May have taken 10 minutes to sharpen the blades with an angle grinder. A lot quicker and easier than I thought.
2014 JLG G12-55A 12,000lbs 4x4 Rough Terrain Telehandler (A55787)
2014 JLG G12-55A...
TRACKLESS MT5TD SERIES V TRACTOR (A51406)
TRACKLESS MT5TD...
30007 (A53424)
30007 (A53424)
2006 International 4300 Altec TA50 50ft Material Handling Bucket Truck (A55788)
2006 International...
2013 Cadillac SRX SUV (A55758)
2013 Cadillac SRX...
2018 Doosan DL220-5 Articulated Wheel Loader (A53421)
2018 Doosan...
