Sharpening Blades
   / Sharpening Blades #1
Bob55
Minn
2006 Cub Cadet Z-Force 44
What is an easy and fast way to sharpen mower blades at home? I have a 6" grinder is there an attachment you can use or some other tool /forums/images/graemlins/confused.gif
Bob
   / Sharpening Blades #2
I USE A 4.5" ANGLE GRINDER WITH A FLAP WHEEL. 6" WITH A GRINDING DISC WILL WORK WELL. MAYBE DRESS THE EDGE WITH A FILE.
   / Sharpening Blades #3
Easy and fast? I'm not sure such a thing exists. /forums/images/graemlins/wink.gif I've used my 6" bench grinder, a 4.5" angle grinder, and occasionally finished the edge on the belt sander.
   / Sharpening Blades #4
I also use the bench grinder. I dont think there is as much concern with balancing on these blades, just take a similar pass on both ends. It's not like sharpening scissors or a knife, you're just trying to put a "decent" edge back on them. They get pretty blunt with a lot of cutting.
Most blades have an wing/angle opposite the cutting edge, you can use that as a guide (sort of) to approach the griinder at the correct angle.
Good Luck.
Curt
   / Sharpening Blades #5
I use a harbor freight el cheapo 4.5 hand angle grinder[actually i like it better than my makita].Try not to get them too hot ,put them in a vise,try to keep original angles,also try to keep each end exactly the same size for balance. remove wire edge and do final touches with a flat file,
T hey work as good as new,unfortunetly every body and their brother wants me to do there blades,more so with the ones with the spiral shaped mulching blades
ALAN
   / Sharpening Blades #6
I just use an angle grinder. After many years of trying to make them perfect, I have found that just a clean up is all it takes. No need to be perfect. Clean and sharp is all it takes, /forums/images/graemlins/smirk.gif
   / Sharpening Blades #7
Bob55,
I bought my Foley-belsaw blade sharpner quite a few years ago so it looks alittle different than the new models, but it works great. I mow 6-7 acres a week, so I sharpen my blades about 5 times a season. Plus I do custom sharpening for anyone who drops their blades off at the shop. I sharpen blade sizes that range from my push mower to my 7 ft. woods finish mower. The sharpeners are alittle pricey /forums/images/graemlins/shocked.gif, but well worth it. Here's a link.
http://www.saw-toolsharpening.com/lawnmowerSharpening01.html
Bill
   / Sharpening Blades
Thanks for all the info. I was hopping to find a attachment for a grinder. If I buy a sharpener form Foley I would have a LOT of lot of happy neighbors. /forums/images/graemlins/grin.gif
Thanks again for all the info,
Bob
   / Sharpening Blades #9
I'll weigh in with those that use a hand grinder to flatten out the nicks, then grind back to the angle, and I finish with a flat broadfile, you'll get a better edge and it'll last longer. I'd also have to say sharp blades make a real diffference in the quality of your cut and it lessens the load on the mower considerably too.
I find the bench grinder is harder to use, cause the blade interferes with the grinder's motor, so it's hard to get a consistant cut across the entire edge.
   / Sharpening Blades #10
For big mowers I use a 4" angle grinder.. for lawn mowers.. I use a little blade sharpener that the hardware store sells for 5$.. chucks into a power drill and has a stone and angle gauge built in.
Soundguy
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2013 FREIGHTLINER EXT CAB SERVICE TRUCK (A51406)
2013 FREIGHTLINER...
2000 INTERNATIONAL 9200 (A52472)
2000 INTERNATIONAL...
NEW Wolverine 72'' Skid Steer Tiller (A53002)
NEW Wolverine 72''...
2020 GP Equipment 24in Excavator Bucket (A51691)
2020 GP Equipment...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
