Rotary Cutter Sharpen or not to Sharpen that is the question
   / Sharpen or not to Sharpen that is the question #11
I have a little Makita that is light enough that I can hold it with one hand and the blade with the other. Wear leather gloves, long sleeves, and goggles.
   / Sharpen or not to Sharpen that is the question #12
sharpen them to cut lawn grass.. leave em 1/32nd dull for shattering brush.. kills the plant.. knicks the blade less.. etc.
soundguy
   / Sharpen or not to Sharpen that is the question #13
I've noticed that none of the Deere operators manuals mention sharpening blades. Only replacement. An attempt to sell more blades?
   / Sharpen or not to Sharpen that is the question #14
I see what you mean...I pulled one at random from the Deere website (LX5 cutter) and nothing about sharpening I could find...
   / Sharpen or not to Sharpen that is the question #15
I was trying to find a picture of the blade profile that I was taught to put on the blades and couldn't find a thing. :laughing:
   / Sharpen or not to Sharpen that is the question #16
Just got the landpride 1872 and manual says not to over sharpen keep them blunt like others say its better to shatter the bigger stuff and it is suppose to mulch tall grass when cutting.
   / Sharpen or not to Sharpen that is the question #17
The manual for my 1995 Bush Hog Squealer specified a 1/8" blunt edge, but I think the newer Bush Hog manuals only mention replacing blades; nothing about sharpening.
   / Sharpen or not to Sharpen that is the question #18
This thread prompted me to check the manual for my rotary cutter -- a Taylor-Pittsburgh 270 (circa 2000). The manual says to sharpen the blades, but gives no specifics about the recommended edge.
I have a relatively new Bad Boy ZTR lawn mower. Bad Boy does not recommend sharpening their "fusion hard weld blades," whatever that means.:confused:
Service / Maintenance | Bad Boy Mowers
Steve
   / Sharpen or not to Sharpen that is the question #19
I "sharpen" mine as per manual and pretty much like kOua and it works well on brush as well as grass. If I want a finish cut on grass, I use a RFM.
   / Sharpen or not to Sharpen that is the question #20
Steve
I'm going to guess the blades are case hardened or built up with a harder alloy weld then ground to a cutting edge.
Sharpening would remove that case hardening (which isn't very deep) or the weld.
I would expect that process if I'm correct) to give extended blade life (3-4 seasons, minimum). If it doesn't, it's a rip off IMHO. I'm leaning toward the "rip off" side.
1988 KENWORTH T800 DUMP TRUCK (A58375)
1988 KENWORTH T800...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
2015 MACK GU713 DUMP TRUCK (A59823)
2015 MACK GU713...
2007 PETERBILT 379 (A60460)
2007 PETERBILT 379...
UNUSED FUTURE FT380 STAND ON SKID STEER (A52706)
UNUSED FUTURE...
CFG Industrail MX15RX (A53317)
CFG Industrail...
