Sharpen chain saw?
   / Sharpen chain saw? #1
Phred
Veteran Member
Arkansas
TN70D, 4wd, 16x16 trans
As you may have noticed from my last post I now have a greater appreciation for how easy it it to dull a chain saw.
The local dealer would be glad to sharpen the chain for me for ~$5 a pop.
There must be a better way.
Who makes a good guide? Any method that folks recommend?
Thanks,
Fred
   / Sharpen chain saw? #2
I just sharpen them myself with a dremel in the basement or an oregon 12 volt sharpener when in the woods. I just try to keep the same angles as the chain had as I do it. I can buy 20" loops online for 20.00 so if I only get a minimum of 7-8 sharpenings per loop I figure I'm still ahead
Kevin
   / Sharpen chain saw? #3
I use a little file that came with the saw when I bought it. Takes about 10 minutes to do. I just chuck the chainsaw into the vise on the workbench (clamp onto the chainsaw bar), and work on one tooth at a time (left-side), then switch to the other side. One of those little sharpener doo-dads that they sell at Northern tool might be a bit quicker (or do like Kevin does), but it really isn't a big deal.
The GlueGuy
   / Sharpen chain saw? #4
i have taught many people to sharpen their own chains and have found it is one of those jobs that not every one can do. although it is not very hard there are a few pitfalls. first like the previous info stated sooner is better, don't wait! the minutes you spend will be made up in faster cutting. second practice on a good chain to get a feel for the top and side angles. with a good chain you will see and feel the proper direction. third only push the file from the back of the tooth to the front, and wear gloves, saw chain will bite you very quickly. fourth the same number of push strokes for each tooth. fifth adjust tension. and finally as you get good at sharpening watch the tooth height compared to the raker height.
James "woody" Mills
   / Sharpen chain saw? #5
I was going to tell you how I sharpen them, but Woody's description is about the best I've ever seen. /w3tcompact/icons/wink.gif About the only thing I do that he didn't mention is to clamp the bar (I use a beat up little vice mounted on a sawhorse) to make it easier to file.
www.GatewayToVermont.com
   / Sharpen chain saw? #6
<font color=blue>push the file from the back of the tooth to the front</font color=blue>
woodmills, Good advise to get the feel of filing on a new chain, the depth angle guide is also a handy tool for starters.
I do just the opposite if I understand what your saying. Why back to front? This leaves a wire edge on the tooth and when it breaks the cutting edge is not as fine. What am I missing? This wouldn't be the first time I found out I have been doing things wrong for 1/2 my life/w3tcompact/icons/smile.gif Also, I have never been too fond of the hand held electric whiz bang sharpening thingy's.
Al
   / Sharpen chain saw? #7
There are two different devices that I have used and like. One is made by Oregon, it is about 1 1/4" wide and alomst as long as the file. The file is secured to this plate which rides on the top of the tooth and the raker controling the file depth. The guide has marks along the top that you line up with the bar controling the angle. The only thing the operator has to monitor is the angle perpendicular (sp) to the bar, usually around 10 degrees.
There is another device I kind of like for a quick fix. It is a little roller guide that fits over the saw chain. You simply lay your file on top of the rollers, which gets you at the right angle and stroke away. Using the proper size file is important. Of course the rakers will have to be touched every once in a while.
Several years ago I made a device that I clamp in the workbench vice that holds the chain like it would be when on the saw. It actually pinches the drive portion of the chain. This way I can turn the chain around and file the akward side with less of a problem. It also holds the chain from rocking while I groom the rakers.
Randy
   / Sharpen chain saw? #8
TT i guess it works front to back as long as you only use the file in one direction. I think my clumsyness would cause more bleeding in that direction.
James "woody" Mills
   / Sharpen chain saw? #9
Excellent advice. I always sharpen my chains by hand, and no longer use the guide. Your advice couldn't be better (I use the vice to hold the bar too), and I hope everyone is doing themselves a favor and listening to you (or is it 'reading' you?). Thanks for the clarity of your message.
   / Sharpen chain saw? #10
There's also an old thread in the Off Topic and Just for Fun forum that covers saw chain sharpening too.
The photo attachments are long gone /w3tcompact/icons/frown.gif but the links are still good.
http://www.tractorbynet.com/cgi-bin/compact/showflat.pl?Cat=&Board=off&Number=23704&page=&view=&sb=&part=all&vc=1
DFB
Cat 66" Skidloader Bucket (A50774)
Cat 66" Skidloader...
2001 Chevrolet Tahoe SUV (A50324)
2001 Chevrolet...
R&G Trailblazer 1000Gal 28% Applicator (A52349)
R&G Trailblazer...
UNUSED AGT SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED AGT SAII100...
2010 Case 660 Trencher (A50322)
2010 Case 660...
SET OF HOMEMADE FORKS (A51243)
SET OF HOMEMADE...
