Sharp corners on FEL leading edge
   / Sharp corners on FEL leading edge #1
RalphVa
Super Member
Charlottesville, VA, USA
JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
JD, if you really care about safety, you'll round off the ends of the FEL leading edge. I was working around it yesterday and leaned over and poked a hole in my forehead.
Called my handyman who happens to have a heavy duty grinder. He came today and rounded off those corners. Took him less than 10 minutes.
Been thinking about doing it for quite some time. JD should have done it.
Ralph
   / Sharp corners on FEL leading edge #2
Not saying what you did was not a good idea, but the way I use a FEL (rocks and dirt) they round down pretty quickly on their own.
   / Sharp corners on FEL leading edge #3
Strange thing, they call them cutting edges for good reason. If it makes you feel better to bang your head on a rounded edge, so be it. I'll take the factory edges for as long as they last and if I hit my head on them, I'll blame myself, not the manufacturer.
   / Sharp corners on FEL leading edge #4
I wonder why they call it Cutting edge ????
I'm not talking about the edge. It's the sharp corners that are the problem. The sharp corners to not affect the digging or carrying ability of the FEL but their presence does affect our safety. They should be rounded by the manufacturer. All it takes is 5 to 10 minutes with the proper grinder.
Ralph
   / Sharp corners on FEL leading edge #6
Might as well go ahead and round the corners of your rear blade, box blade, mower blades, bushhog blades, etc.
And heaven forbid if you ever put a tooth bar on it.
   / Sharp corners on FEL leading edge #7
How much did he charge you to round off the corners?
   / Sharp corners on FEL leading edge #8
Easy guys...he is sharing his personal experience in hopes no one else would have the same accident....nothing wrong with that :thumbsup:
   / Sharp corners on FEL leading edge #9
And factor that into an added cost for everybody for something they dont want. Most would rather cause that wear by using the loader.
larry
   / Sharp corners on FEL leading edge #10
You want sharp edges on a cutting edge to assist in cutting desired grade. It is the operator's responsibility to operate any piece of equipment in a safe manner. By the way there are corner cutting edges on some equipment. The manufacturer has no liability on incorrect use of said equipment. IMO, if they are looking to shift responsibility to manufacturer then they should not use the equipment.
JPC
550 Tubes Grease Cartridges (A53117)
550 Tubes Grease...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
Dry Gel Hydration Unit (A53843)
Dry Gel Hydration...
2024 JOHN DEERE 35P LOT NUMBER 107 (A53084)
2024 JOHN DEERE...
