Oil & Fuel Shared or seperate oil? MT2001
/ Shared or seperate oil? MT2001 #1
sharpiepyg
Farmington Hills, Michigan
Mitsubishi MT2001
Okay I guess I give up, and need some help. All my "manuals" tell me I have seperate oil for my transmission and hydraulic system. SO I went out and bought the recommended fluids. I see drain plugs and fill cap for the trans, but I see no way to refill the hydralic side. It appears to have it's own drain plug. I also thought I would fill it where the filter is, but as I look at it closer, the filter sits lower than the reservoir. At least that's how it appears, so how can I fill something at this lower point? So then maybe my fluid is shared and I fill the entire thing from the one on the transmission? Does anyone know for sure? If it is shared, what combo-oil should I use? Originally I was told 80W-90 for the trans, and AW26 for the hydraulic.
/ Shared or seperate oil? MT2001 #2
Well you could just leave a drain plug on the hydraulic side out and pour some oil in to really see if it is shared or not.
/ Shared or seperate oil? MT2001 #3
I would be surprised if the trans and hydraulics were not a shared system. I have a similar model and they are shared on mine, but more than that, I am pretty certain the gear drive Mitsubishis are all set up that way. I have several drain plugs but they both drain the same system. I think wushaw is right, if in doubt add some trans fluid and see if it comes out of both drain plugs, if it does it is a shared system...which I think you will find it is. If it is shared I think you can use any of the trans/hydraulic fluids available at dealers or farm supply stores.
Thanks for the advice. I may just do that as I'm not seeing any other way to get the hydraulic oil in there if it is NOT a shared system.
The universal fluid that I need, is it also this "303" fluid I see? Living in metro Detroit I don't have the luxury of the TSC or farm/fleet stores. I have to rely on Autozone or Walmart, places like that.
/ Shared or seperate oil? MT2001 #5
Walmart in my area carries a Rotella tractor fluid, you may look there.
SDlanch SDLGC80 (A60462)
SDlanch SDLGC80...
Kuhn FC400RG (A60462)
2015 WACKER NEUSON G50 TOWABLE GENERATOR (A64279)
2015 WACKER NEUSON...
2014 Nissan Quest Van (A61574)
2014 Nissan Quest...
2018 INTERNATIONAL LT625 DAY CAB W/ WETLINE (A62613)
2018 INTERNATIONAL...
2006 Ford F-150 Ext. Cab Pickup Truck (A61573)
2006 Ford F-150...
